Results 1 to 18 of 18
Thread: Swordfish Pro 200 and 220
    Jan 2008
    VA
    3,070
    Default Swordfish Pro 200 and 220
    Steve recently got some Swordfish controllers in stock. What's the word on the Pro 200 and 220 controllers? I'm debating trying one out for a P-Mono heat racer. Anyone have any input??
    Mar 2011
    BC
    7,630
    Got a couple 220's, seem great so far. Watch the hard start setting. If you go to putter in it can jump.
    Jun 2011
    789
    I bought two of the early 220's from KBR and for whatever reason they would cut out similar to when you hit low volts on "D" winds. No problem with "Y" motors. Other than that I have had good results with SF200 esc's. 300a not so much.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Aug 2013
    Fl
    2,451
    I've got 220 pro pluses in three of my boats and all run great Y and D wind motors. I've also got a pair of 200 pro pluses for a Cheetah twin build I'm doing, haven't run those yet but I'm sure those will work fine too.
    Sep 2013
    pa
    65
    i have a leapord 4082 that keeps cutting out with the sf 220+ what is doing that?
    Aug 2013
    Fl
    2,451
    Quote Originally Posted by dennislawler11 View Post
    What do you have the LVC set at? and what is the rest of the setup on the boat? KV, Prop, size of boat, batteries, ETC.?
    Sep 2013
    pa
    65
    it is a 34 inch tunnel 2000 kv x447 prop 4s 5000mah 45-90c it says the lvc should defalt to 3.2. my usb link for the esc should be here tommorow.
    Aug 2013
    Fl
    2,451
    Everybody is different but I set my LVC @ 3.0 volts. What kind of temps is it running? That might be a little too much prop for that setup try backing up to a 44 or 45mm prop and see if it still does it
    Sep 2013
    pa
    65
    the temp seemed normal i will try backing off the prop thank you
    Sep 2013
    pa
    65
    it does seem to cut out even out of the water. is that normal?
    Nov 2008
    NJ
    164
    Dennis,
    I am running a SF220+ with data logging and 4s in a few different boats.
    Had a few instances were the boat stopped during testing. I checked the amount of amps and it was as high as 280. This controller is only rated for 220 amps continuous. I had way too much prop.
    When I propped down everything was good.
    Check it out
    Sep 2013
    pa
    65
    would it do that even out of the water?
    Aug 2013
    Fl
    2,451
    It shouldn't do it out of the water because there's no load on it, if it's doing it out of the water you got other issuses
    Oct 2009
    MI
    6,192
    What kind of experience are people having racing these? Guys have them in our club. I've never really checked them out though.
    Be careful with the LVC on good cells. I set mine at 3v too but my GP packs and even some of my oldest Hyperians will deliver 3 volts until the tank is stone empty.
    Noisy person
    Dec 2011
    NY
    1,447
    I ditched the LVC cut off with my seaking escs now they're fine. With high quality packs like dinogy I didn't have a problem but with my zippy packs I was hitting lvc.
  16. #16
    Oct 2009
    MI
    6,192
    Is the timing adjustable in 1 degree increments on these?
    Noisy person
  17. #17
    Aug 2013
    Fl
    2,451
    The newer versions that I have (after 12/4/12) are adjustable in 2 deg. increments. I'm sure everything you'd get new will be this way, I've got 6 or so boats with these in them and have had zero problems out of any of them.
  18. #18
    Jul 2012
    Wa
    867
    I just bought 1 of 2 SF-200 8s for my modified Zonda that is using the TP4050 2220kv motors I will be using the esc on 6s and some lipos that no one here has tried in boats the SMC 6500 70-140c race formula hard packs that are used in cars.
