Steve recently got some Swordfish controllers in stock. What's the word on the Pro 200 and 220 controllers? I'm debating trying one out for a P-Mono heat racer. Anyone have any input??
Mike Chirillo
www.capitolrcmodelboats.com
Got a couple 220's, seem great so far. Watch the hard start setting. If you go to putter in it can jump.
I bought two of the early 220's from KBR and for whatever reason they would cut out similar to when you hit low volts on "D" winds. No problem with "Y" motors. Other than that I have had good results with SF200 esc's. 300a not so much.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
I've got 220 pro pluses in three of my boats and all run great Y and D wind motors. I've also got a pair of 200 pro pluses for a Cheetah twin build I'm doing, haven't run those yet but I'm sure those will work fine too.
i have a leapord 4082 that keeps cutting out with the sf 220+ what is doing that?
it is a 34 inch tunnel 2000 kv x447 prop 4s 5000mah 45-90c it says the lvc should defalt to 3.2. my usb link for the esc should be here tommorow.
Everybody is different but I set my LVC @ 3.0 volts. What kind of temps is it running? That might be a little too much prop for that setup try backing up to a 44 or 45mm prop and see if it still does it
the temp seemed normal i will try backing off the prop thank you
it does seem to cut out even out of the water. is that normal?
Dennis,
I am running a SF220+ with data logging and 4s in a few different boats.
Had a few instances were the boat stopped during testing. I checked the amount of amps and it was as high as 280. This controller is only rated for 220 amps continuous. I had way too much prop.
When I propped down everything was good.
Check it out
would it do that even out of the water?
What kind of experience are people having racing these? Guys have them in our club. I've never really checked them out though.
Be careful with the LVC on good cells. I set mine at 3v too but my GP packs and even some of my oldest Hyperians will deliver 3 volts until the tank is stone empty.
Noisy person
I ditched the LVC cut off with my seaking escs now they're fine. With high quality packs like dinogy I didn't have a problem but with my zippy packs I was hitting lvc.
Is the timing adjustable in 1 degree increments on these?
Noisy person
I just bought 1 of 2 SF-200 8s for my modified Zonda that is using the TP4050 2220kv motors I will be using the esc on 6s and some lipos that no one here has tried in boats the SMC 6500 70-140c race formula hard packs that are used in cars.
