Took the boat out today. It ran well, got up on plane pretty quickly and turns nice without any turn fins.
I noticed very little, if any water comming out of the cooling discharge hole so I brought it in. Didn't have a thermometer with me but the ESC and Lipo's had not a lot of heat, but the motor, WOW! It was really hot.
The cooling system on this boats has water making two passes through the ESC, and one through the motor. I'm sure that the several passes through the ESC creates a signifficant amount of back pressure. When I assembled the hoses I blew through the pickup and air came out the discharge, but there was a lot of resistance.
I suppose the obvious modification would be to add a second water pickup specifically for the motor? If the ESC was not hot, and there was no water flow, would it be safe to bypass the ESC and run the water directly to the motor (for a short run)?
Electrical set up was: KB36 11XL motor, Castle Creations Hydra 240 speed control, Elite 4S 4500 30c lipo’s. This all pushes a 42mm 3 blade prop.
There is a fine line between "hobby" and "mental illness."
