Results 1 to 9 of 9
Thread: Octura X431 vs Aquacraft stock Mini Rio prop?
    Default Octura X431 vs Aquacraft stock Mini Rio prop?
    Hey guys just got my Octura X431 prop and I can't tell the difference between it and the stock FRP Mini Rio prop. Are there any specs on the stock Rio prop? It'd be a shame to have expected any difference to get none... I mean its red, instead of black.. which is cool but, ya know..
    I am going to go to the local park and try it out as soon as my other battery is done charging.
    But, whats 1mm really do? I can't even measure the difference really with calipers. Is the pitch the same?
    Thanks all!
    ma
    8,693
    Not sure what it is with the stock prop, but its not that good on takeoff. I have used other similar sized pops with the rio and noticed a large increase in take off speed. So, give it a try and let us know?
    Steven Vaccaro
    ma
    8,693
    Steven Vaccaro
    Tried it out! It seems to take off and get on plane way faster. If I had to guess I'd say it gets on plane in half the distance of the stock prop. I bought a VR3 motor so hopefully I get that this week and I'll swap it out and see if it gets any faster.
    NJ
    1,322
    The VR3 should make it FLY!
    WWW.PPRSLOTS.COM
    Quote Originally Posted by SweetZ28 View Post
    Really? Its a good swap? Stay on the stock battery? My VR3 should be here sometime in the next couple days I'd think
    NJ
    1,322
    Get a better battery ...if you use the stock one solder thicker wires on it .
    WWW.PPRSLOTS.COM
    When you say solder thicker wire - do you mean from inside the battery or from the outside? What gauge? Any pics?
    NJ
    1,322
    Yes rewire the battery pack.... the stock wire is so thin a guy had his melt and short out.... 20 gauge should be good.
    WWW.PPRSLOTS.COM
