Results 1 to 15 of 15
Thread: New to brushless
    Dec 2008
    Sy
    59
    Default New to brushless
    Hi all. I have a polystyrene NQD 26" mosquito craft mono hull to play with. It came with 2 x 380 size brushed motors and I can walk faster than it goes.
    I know it's not a very good boat, I don't mind, it's all I have and can afford. I would like to stick some power up its transom to see what it's capable of.
    I'm looking at getting a brushless set up for it.
    I have purchased a water cooled motor mount, adjustable stinger drive, 3/16 flex shaft assembly and made a battery/servo cradle. Now I'm looking at a getting a brushless motor, lipo battery and prop. Any suggestions (apart from tossing it in the bin) would be well received.
    I have included pics of the boat (disregard the motor, it's just for show) to help with any suggestions you may have.
    Cheers, Brett.
    Jan 2013
    La
    295
    I am all for being hard headed but your are better off buying a new boat that size
    Rtr Verses piecing together motors esc shafts props etc for that boat. It will cost about the same or less
    Sep 2010
    nj
    4,289
    That hull will work but you better beef up the transom for the hardware to bolt to,
    Or it will rip out from stress load put on it.
    You can make it run pretty go with a cheap HK motor and esc.
    What lipo cells do you have on hand or do you want to run in it ?
    Syma" twin motor. I have a Feigao 3660 1898kv in it on 4s, single drive,
    Hears some vids of a 27" one when done right.
    ? ONLY IF THEY WORK
    Sep 2010
    nj
    4,289
    Little better one.
    ? ONLY IF THEY WORK
    Dec 2008
    Sy
    59
    Nothing wrong with that! It's about all I'm looking for.
    I was thinking a 2300Kv 4 pole leopard motor with a 120amp ESC turning a 42mm 3 blade prop on 4s 65c, based on a little research.
    Would that be a good combo?
    Sep 2010
    nj
    4,289
    That should work,
    It Just a little high on the kv for 4s setup and that hull.
    I am running a 2700kv in my modded 26" Rio ep,
    But I just run it on 2s and 3s with speeds of 30mph to 44.5mph tops now.
    ? ONLY IF THEY WORK
    Dec 2008
    Sy
    59
    Might have to re-think the KV. Thanks for the advice.
    Nov 2008
    Ql
    3,169
    That's what I did for my first "Fast Electric" boat. Ahhhh The memories.
    Originally had a Johnson 785 brushed motor in it on 12 of the old round cells. Then an Ammo 2300kv motor on the same old cells with a 437/3 blade prop. Here's a video from the archive with the Ammo. This is all before I ventured into Lipos.
    Go for it man.
    Dec 2008
    Sy
    59
    So should I use the 2300kv but downsize the prop? That boat was going quite well.
    Sep 2010
    nj
    4,289
    785boat,
    I have no idea how you posted a hydro when we are looking at a mono setup.
    That thing rides on a pocket of air most of the time at high speeds.
    TH no,
    Lower kv cooler running and also you can go up in cells or prop up down the line for more speed.
    If it is setup with the right kv and esc from the start.
    ? ONLY IF THEY WORK
    Dec 2008
    Sy
    59
    So 2700KV Lenny?
    Sep 2010
    nj
    4,289
    What cell volts do you want to run in the setup ?
    ? ONLY IF THEY WORK
    Dec 2008
    Sy
    59
    Probably 4s 65c at this stage.
    Jan 2013
    La
    295
    Its not that simple. That boat was a labor of love. Probably 15 hrs modifying it.
    Sep 2010
    nj
    4,289
    I would go for a 1800kv to 2000kv than you could run 3s to 5s tops,
    And be a cool running setup to.
    Hear a very little bit of info in this build thread and some pictures.
    https://forums.offshoreelectrics.com/...hlight=villain
    Like I said about the transom in this vid.
    ? ONLY IF THEY WORK
