I just wanted to advise those who want to run their SV motor with something other than the stock speed controller. Do yourselfs a favor and do not use any other speed controller other than the stock Aquacraft one. I have bench tested the SV with a Hydra 120 and found that the motor (which had been ran and tested with the stock speed-o) would get hot. I read on the red board that someone did run theirs and it got hot. Someone else suggested that he had a bad motor (which I do not beleive is the case). I also know of 2 other boaters who melted their motor and speed controller by using something other than the stock unit. Some have said they work (other controllers) but I know that they are limiting the life of the motor and maybe the speed-o. Just thought you all might like to save yourselves some heartache and $.
Also, in the red board post...the author noted that the motor was out of balance with the other speed-o. I came up with the same results with the Hydra. When I put the motor back on the stock speed-o it ran just fine again. The pulses or waves must not be condusive for the windings of the motor.
