I was running my IM31V2 yesterday when it flipped even though the hatch was taped down it cam of and cracked and chipped in a few spots. The plastic lid of course sank and the boat took on a lot of water. When I got it out I unhooked the batteries and set it in front of a fan over night once I got home. I'm running the stock RX/TX a Leopard 4082 1600KV and Seaking 180amp ESC with disabled BEC and separate RX pack. this morning I put some batteries in to see if everything would still work and all I get is steady beeps from the ESC and the motor will turn just a bit in on direction then the other back and forth with in tune with the beeps. This is what it does if something is wrong. For example if you don't have a rx batt hooked up or your rx/tx are not bound it's a warning the esc gives off I guess. This happened one time before after taking on water and all I had to do was rebind the RX/TX and everything was fine. The problem is the RX this time is acting just like the last time when I plug in the rx pack it lights up for a split second and the servos moves a tiny bit if I reverse the rx plug the rx light stays on and the servo will go all the way to on direction. The difference this time is that I can't get it to go into bind mode. with out that I can't see if the motor and esc are ok although it would seem they are. the motor is not stuck and the esc does beep and the red light flashes. I'm thinking the RX is bad but really not sure. Anyone run this or similar setup I could use some help. Thanks
