Thank you Doug cheers
Thanks Tiqueman, much appreciated. How you getting on with your boat?
Hey mate, I used Savox 2270sg High volts..
The problem was, I run Futaba and they say to run the reciever R603FS at 6v max.
Ive found a few people who just run off a lipo @ 7.4v anyway and say its been fine.
But didnt wana risk this much money on a $90 reciever blowing up while im going flat out and may need to turn lol.
So to use the 2270's to there max potential somewhere around 444 Oz-in @7.4v i used a Gryphon Regulator.
You plug your 1 or 2 servo leads into a specific slot and according to what slot its in theres little Dil switches on the back and you can select to step up the voltage or step down etc.
So i have the reciever slot set @ 6v and the 2 servos set @7.4 and the unit its self is obviously a 2s lipo . Make sense?
I use them in my Heli's.
I also turn everything on and off via this.. Has a flag that saids " Remove before flight" lol i hope not
Here it is if you wana check it out.
http://arkrc.com.au/products/GVR%252...2d-Silver.html
Cheers Ryan
