Results 1 to 19 of 19
Thread: Completely Submerged Revolt 30, please advise
    Nov 2013
    36
    Default Completely Submerged Revolt 30, please advise
    hi there, so just a few minutes ago, i had my revolt 30 out on the water with my brand new first time used turnigy 4s battery. I got caught on some lilipads, tried to use the pool life raft to get it out, and hit the top off the boat (yes it was taped down) and then after a while the boat started sinking, so i had to wade in there and get it. The entire boat was submerged, so rather than let the algae ridden pond water sit in there, I just rinsed everything down, now what?
    is the battery going to be ok?
    servo?
    brushless motor?
    control receiver?
    thanks all!
    1,431
    If its still pretty wet ou can douse it with distilled water to get the rest of the pond water off. I'm guessing ou don't have any corrosion x on hand? If you have wd40 you can spray that directly into the motor and on the bearings. Set up a fan and let it air dry for no less then 24 hrs. Don't try to power it up too soon or you will ruin it. If you let everything dry out completely you should be able to salvage everything. I would wait 2 days for it to dry to be on the safe side.
    Nov 2013
    36
    sweet thanks, do i spray wd 40 through the cooling lines? or right into the motor where the coils are, or both?
    Apr 2013
    777
    Rice is a good dessicant.
    1,431
    Where the coils are. Ideally it should be removed. After the wd 40 soak if you have an air compressor I'd blow it out. The motor should be fine for sure. It's the speed control, servo and rx you need to worry about. The AQ esc's are sealed up pretty good though so that should survive just fine also.
    May 2012
    940
    Ouch
    Do It Like You Mean It .....or Don't Bother
    Nov 2013
    36
    thanks for the help guys, so, i put the battery and the controller receiver (tons of water inside, this one might not survive) in a bag of rice, wd40'd the motor. I'm going to wait til sat to start it up again, hope everything works
    7,630
    If the controller wasn't powered up it may be fine. Rubbing alcohol will a also displace water on electronics. Definitely leave all parts alone for a few days to a week after.
    Nov 2013
    36
    the boat was still plugged in with controller on when it went under
    7,630
    Still my experience(and plenty of it) that as long as you did not hit throttle it may live. Mostly my Castle's here but try it out in a week
    Nov 2013
    36
    cool, yea no throttle for me, i was too busy fishing it out to hold the controller :)
    Oct 2013
    la
    8,740
    Huh? Its a boat but not water proof? My shockwave 26 got sunk a few times and I poured the water out and went right back to running it. All the equipment in it was claimed to be water proof. I went one step farther later on and coated everything electronic in epoxy. I don't drive well and I like to go really fast and that usually ends up in me sinking something. The epoxy works. I sink. Drain water out. Go back to running it.
    Nov 2013
    36
    glad to hear all of this, looks very promising!
    Apr 2013
    337
    My proboat combo and traxxas servo keep on ticking. I've sustained a few flips with my elam ending completely submerged. I just let her completely dry with the cowl off and she always works great the next time. I use a waterproof box for the receiver.
    7,630
    The Rx is the most forgiving. A little alcohol douse, dry, and off you go.
    Sep 2012
    IA
    274
    rx- Corrosion-X! Spirits might do more harm!
    1,969
    I've had the AQ ESC under water several times and it survived-- it is highly water resistant.
    Chief
    1,969
    Quote Originally Posted by nammer View Post
    No need to do anything with the cooling lines-- the job of the cooling lines are to pump pond water into the water jacket and cooling plates on the ESC.
    Your motor will work fine when dry, but using corrosion X can help extend the bearing life. I have an OPC tunnel with an exposed motor, so every time it capsizes it is under water (which is about every time I run it!).
    Chief
    PS, motor bearings can and should be replaced periodically
    Nov 2013
    36
    update, came back from vacay, put everything back together, plugged in battery, looks good to go, thanks for everybody's help!
    AquaCraft Revolt 30
