Results 1 to 13 of 13
Thread: Turnigy marine t-120 esc
    Sep 2012
    IA
    274
    Default Turnigy marine t-120 esc
    Yes, I've got another Turnigy marine t-120 amp esc and took a good look and see the 2 caps are 470uF 35v and think that isn't enough. Anyone knowing the exact caps will be appreciated and how many. Oh yes, thanks! I just never looked at the other esc and took it for granted as it work alright.
    Sep 2010
    nj
    4,289
    My t-120a had two 35v 390uF caps that were bad,
    And I replaced them with two 35v 1000uF caps and the esc works good now.
    ? ONLY IF THEY WORK
    7,631
    My t-120a had two 35v 390uF caps,
    I replaced the with three 35v 1000uF caps and my setup works a lot better now in my 36"shockwave modded to FE.
    Your only running a 120 in that hull Len?
    Sep 2010
    nj
    4,289
    Yep.
    Same t120a with the two stock caps and I added three 35v 1000uF caps to control the temps better,
    When I modded the shockwave to FE with the 9xl 1898kv Feigao start with.
    Than the motor shaft bent so I tried the 4074 1800kv and have the 2200kv in it now.
    ? ONLY IF THEY WORK
    Sep 2012
    IA
    274
    Wait a minute; post #2 says you HAD 2 factory caps and replaced them with 3 -1000 and post #4 says you didn't replace the factory caps but added 3 - 1000 ????????????
    Sep 2010
    nj
    4,289
    Sorry I just looked at it again today.
    Post #3 is right for the 36" shockwave and esc,
    It has been about a year or more when did it to that one.
    But in post #2 I did that one about 3 months ago,
    And I just took the two bad stock caps off and replaced them with two 35v 1000uF caps and it works good now.
    ? ONLY IF THEY WORK
    Sep 2012
    IA
    274
    Thanks, not causing trouble but thought my glasses were dirty or floaters were occurring, don't get OLD!
    Sep 2010
    nj
    4,289
    Quote Originally Posted by Southwest View Post
    Well I guess it beats the alternative.
    ? ONLY IF THEY WORK
    Sep 2012
    IA
    274
    I found my t-120 caps weren't soldered on the + end on both and esc got hot, scratch 1 t-120.
    9,402
    I did this to the HK T120 esc. Runs really nice.
    I don;t trust those 2 tiny caps on there. This is not the easiest thing to do but, not super hard. I removed the originals immediately and added 130*F 35V-1000uF caps instead.
    Sep 2012
    IA
    274
    Ray, where did you find the 130*F 35 v-1000uF caps at. I went thru and found 105*f 35v-1000uF caps only!?
    9,402
    From the Cap King out of NY. CAPS They are not the lowest Impedence caps but, if Etti uses them they have to be pretty good.
    I have heard one person bought certain caps from him that did not work well but, not sure which ones but, not these though. These seem to work well.
    I think it's a good idea to test them first to make sure they charge properly. just put a meter to resistance scale and watch them charge. If you had a capacitor checker, that would be even better but, they are pretty expensive I think.
    Sep 2012
    IA
    274
    Ray, thanks! I'll check into a cap check today!
