Results 1 to 5 of 5
Thread: imp 31 basics
Hybrid View
    Oct 2013
    va
    28
    Default imp 31 basics
    I purchased a used gen one with adjustable tabs ,the boat needs to get back more on the pad im running 4s on stock motor and esc with a grime reapor 45x22 sharpened and balanced,what angle should I set the plates at they have to be undone to adjust so I would like a good start point if I can get one
    Im looking for speed and a good handling boat right now it digs the nose and flips
    Mar 2013
    ny
    367
    you don't need the trimtabs on that hull ,i put mine all the way up and 0° angle
    i guess your strut has to much negative angle :so it's pusching the nose to much down
    maybe a picture of the back?
    Oct 2013
    va
    28
    over the weekend I made some runs with the prop shaft as far up as I could get it and it still stayed pretty level my tabs were at 0 degrees
    Oct 2013
    va
    28
    boat met a turtle at high speed and is now totalled
    Nov 2009
    CA
    1,969
    Sorry to hear about that-- those things are like lake land mines...
    If you get another impluse I have a useful setup/running guide (for the V2) that also covers upgrades and prop selection, it is a word file, if you would like a copy of it my email is jqhydro@gmail.com. I personally like the x642 for the stock setup.
    Chief
