Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: TFL Carretero
  1. #31
    Oct 2009
    MI
    6,192
    Did finally get this baby wet. Runs really smooth. Might need more fin on the right side. Haven't quite figured out the prop situation yet either. Needs big 2 blade that I just don't have. Like maybe 462 sized. I can't even warm the batteries up with the props I own.
    Sure looks sweet in the water though.
    Noisy person
  2. #32
    WA
    8,335
    Terry,
    What SHAPE are the current turn-fins. If they are tear-drop shaped (seems to be the rage these days), try something more like this:
    ProBoat Impulse 31 V1 & V2 Turn Fins by OSE
    http://www.offshoreelectrics.com/pro...?prod=ose-1400
    I assure you, it WILL be better, especially in real race water...
    Darin E. Jordan - Renton, WA
  3. #33
    Oct 2009
    MI
    6,192
    Maybe. I suspect it's a size thing though. I try to use the smallest fins I can get away with but this things weights a bunch with 8s12000mah.
    Noisy person
  4. #34
    WA
    8,335
    Size matters, but surface area counts as size... :) The difference between finishing a P-Ltd Mono or Offshore race with an IM31 is these fins over the stock teardrops, and these aren't as deep... The boat is a full-throttle pin it in the corner boat with these. It's rolled over upside down with the stock ones...
    Hey, I'm just here to help!
  5. #35
    Oct 2009
    MI
    6,192
    I have a number of fins I need to invent. My Q sport absolutely can not hold a turn. I do have a plan for that at least.
    I nice sheet of fin on this would be easy enough to do.
    Noisy person
  6. #36
    ON
    9,402
  7. #37
    Oct 2009
    MI
    6,192
    oh.....Square straight fin with a whole and an edge on it. Super easy to do its all I meant.
    Noisy person
  8. #38
    ON
    9,402
    I tried a set of small Speedmaster's cut down for my P-mono and it turned like crap... not the fins problem just the rest of my setup didn't like them... Pond time... there is never enough.
