Results 1 to 20 of 20
Thread: 1/8 Scale hydroplane turn left set up
    Sep 2013
    WA
    108
    Default 1/8 Scale hydroplane turn left set up
    Hello,
    I was wanting to set up a 1/8 scale hydroplane to turn left and wanted a reliable setup that I can count on so I don't need to break any speed records plus this is not to race in any club. I need help with esc, motor, right hand prop suggestions. I also was going to use 8s setup or any other input would help thanks for looking.
    To be clear, you want to run counterclockwise ovals, right? What hull do you have? What are your speed and run time goals? What is your budget?
    Sep 2013
    WA
    108
    Correct I'm going to run counterclockwise and was going to order rc boat company hull T-6. I wanted a little more run time than speed (45mph to 50mph) and budget is open. Thanks for replying
    Sep 2013
    WA
    108
    Scorpion 4035-800 brushless motor I was looking at this motor any thoughts about this
    Sep 2013
    WA
    108
    Magnet Poles 8
    Motor Wind 6 Turn Delta
    Motor Wire 27 - Strand 0.29mm
    Motor Kv 800KV RPM / Volt
    No-Load Current (IO) 2.5 Amps @ 8.4v
    Motor Resistance (RM) 0.010 Ohms
    Max Continuous Current 100 Amps
    Max Continuous Power 4200 Watts
    Weight 435 Grams (15.34 oz)
    Scorpion 4035
    May 2012
    NE
    9
    Something to think about is finding a turn fin that is cuped on the right side and you may have to reshape the bottoms of the sponsons to get the boat to slide in turns unless the company will mold the hull for counter clockwise running.
    Sep 2013
    WA
    108
    Quote Originally Posted by jwray View Post
    Thanks for the details
    Sep 2013
    WA
    108
    Any suggestions on lipo setup like c rating and 6s, or 8s etc
    Wa
    5,905
    8 to 10 S and I would think at the very least 35c (quality cells)
    Billy Graham
    Sep 2013
    WA
    108
    Should I use 1 or 2 packs
    Wa
    5,905
    Dont know if a single pack will fit in your boat. My guess is two would work better for weight distribution
    Sent from my SGH-T989 using Tapatalk 4
    Billy Graham
    Sep 2013
    WA
    108
    How many mih for total battery capacity
    Sep 2013
    WA
    108
    How much total battery mah capacity should I use and any prop suggestions or esc
    Sep 2010
    588
    I have a Scorpion and it pushes my 19 lb PAy N Pak 60 MPH on 10S
    Bob Zola NAMBA 212
    2022 NAMBA Nationals FE High Points Champion
    Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
    Sep 2013
    WA
    108
    How many mah are you running on the battery's thanks
    Sep 2013
    WA
    108
    What kind of run time are you getting thanks
    Sep 2010
    588
    2 5000 mha 5S packs in series so 5000 mha of 10S. I only ran a mill lap plus 6 lap heat on a 1/6 mile course. Used about 3200-3500 mha.
    Here is a video of the boat running that motor:
    http://www.youtube.com/watch?v=rMKamNMFlPE
    Bob Zola NAMBA 212
    Sep 2013
    WA
    108
    Thanks for the video what was the c rating on the batteries
    Aug 2012
    ny
    1,359
    get 2 5S 6000mah Dinogy packs, the scorpion motor works great, you will get better run times and lower temps w/ the 65C dinogy batteries, and they're only a few bucks more than the cheaper ones. Yes these hulls are made to run clockwise so the L and R sponsons usually are different.
    We call ourselves the "Q"
    Sep 2010
    588
    I had 25C packs and ended up flaming them up. I would recommend going to higher C rating. I am becoming a fan of the Dinogy batteries myself. Take Mr. Pags advice!
    Bob Zola NAMBA 212
