Results 1 to 7 of 7
Thread: Push-pull dual arm rudder control
    May 2008
    Oz
    2,981
    Default Push-pull dual arm rudder control
    Searching for push pull rudder control for cat.
    None around !
    So
    Spoke to this place who had som made cnc
    Very cool !
    http://shop.rcboatbitz.com.au/index....oducts_id=1653
    7,631
    That appears to be for Speedmaster?
    May 2008
    Oz
    2,981
    rudder mount hole centers are 22.5mm(7/8") apart
    Yes, it does fit the speedmaster brackets.
    Sep 2013
    Ny
    32
    yes, it's so cool...
    Nov 2013
    Fl
    825
    Like this one from Kintec. It's the whole rudder system and it's $55 but sure is nice. Was a little to big for 37" Daytona I'm building.
    I used a smaller bracket and bent linkage so I could have a push-pull set up.
    May 2014
    Wi
    25
    Any thoughts as to where I can get a replacement set of just the cables & the sleeve?
    Aug 2013
    Fl
    2,451
    Quote Originally Posted by M3Man03 View Post
    Kintec has just the cables and rams seperate. http://kintecracing.com/Hardware.html scroll down to almost the bottom.
