lol i know what you mean . its just i cant get to try and build it
snort pixi sticks=symptoms-:
My thought here is that on a dual rudder setup it should be much more stable in the turns and should not need the turn fins. Im betting drag will be not much of an issue and weight should about cancel out the turn fins........thoughts?
been quiet for a while, been busy. But here is the concept for the dual rudder system. Simulates VERY nice in solidworks.
very nice.
an RC rock crawler lost in a sea of boat parts.........
nice!
Is there enough room to move the strut up/down/tilt?
just making sure the connecting rod is not crossing over it.
it looks like if it where to have a prop when it turned it looks like it would hit the rudder
quick question. I'm about to start drawing up the strut now. I have no idea as far as what the drive cable looks like.
It's basically a .150d cable, with a 3/16" shaft welded to the end of it? That would mean the bushing inside diameter on the strut would have to be 3/16" correct?
ok, here's what we got....
here are a few angles...the strut bracket stick up at the top because it will be slotted for adjustment, which will make this fully adjustable to anything you have. Right now it's inline with the stock stuffing tube.
rear view with and without transom...
and top view of the sweep. lots of clearance for everything...
got some more drawn up. here you can see I added a feature to the strut which will allow for a water pickup. I've also drawn in a makeshift octura x642 prop. I've actually oversized it quite a bit on the drawing to see clearances, and as you can see, there is plenty of room on both ends of rudder travel.
