Page 2 of 2 FirstFirst 12
Results 31 to 44 of 44
Thread: New hardware taking shape
  1. #31
    Dec 2007
    long island
    498
    lol i know what you mean . its just i cant get to try and build it
    snort pixi sticks=symptoms-:
  2. #32
    Jul 2008
    WA
    772
    My thought here is that on a dual rudder setup it should be much more stable in the turns and should not need the turn fins. Im betting drag will be not much of an issue and weight should about cancel out the turn fins........thoughts?
  3. #33
    Jun 2008
    ON
    896
    been quiet for a while, been busy. But here is the concept for the dual rudder system. Simulates VERY nice in solidworks.
  4. #34
    Jul 2008
    WA
    772
    very nice.
    an RC rock crawler lost in a sea of boat parts.........
  5. #35
    Aug 2007
    CA
    3,031
    nice!
    Is there enough room to move the strut up/down/tilt?
    just making sure the connecting rod is not crossing over it.
  6. #36
    Jun 2008
    ON
    896
    Quote Originally Posted by Ub Hauled View Post
    nice!
    thanks guys. ya it shouldn't be a problem. I already had to put some offset spacers under it to make clearance for the servo horn. If need be, the spacers can be a bit taller. All will be proven out before anything gets made. That's the beauty of solid works. hehe.
  7. #37
    Dec 2007
    long island
    498
    it looks like if it where to have a prop when it turned it looks like it would hit the rudder
  8. #38
    Jul 2008
    WA
    772
    Quote Originally Posted by crazzy maxx View Post
    a 3" prop maybe
  9. #39
    Jun 2008
    ON
    896
    nah it only looks like that. there is tonnes of space. I'll probably draw in a make shift prop when I'm done to show the clearances
  10. #40
    Jun 2008
    ON
    896
    quick question. I'm about to start drawing up the strut now. I have no idea as far as what the drive cable looks like.
    It's basically a .150d cable, with a 3/16" shaft welded to the end of it? That would mean the bushing inside diameter on the strut would have to be 3/16" correct?
  11. #41
    Jun 2008
    ON
    896
    ok, here's what we got....
    here are a few angles...the strut bracket stick up at the top because it will be slotted for adjustment, which will make this fully adjustable to anything you have. Right now it's inline with the stock stuffing tube.
    rear view with and without transom...
  12. #42
    Jun 2008
    ON
    896
    and top view of the sweep. lots of clearance for everything...
  13. #43
    Jun 2008
    ON
    896
    got some more drawn up. here you can see I added a feature to the strut which will allow for a water pickup. I've also drawn in a makeshift octura x642 prop. I've actually oversized it quite a bit on the drawing to see clearances, and as you can see, there is plenty of room on both ends of rudder travel.
  14. #44
    Sep 2007
    CA
    502
    Quote Originally Posted by kookie_guy View Post
    Ya that would make sense if you make the the same size the bushing wont fit. So yes make it one size bigger.
    Failure is the First step to SUCCESS
