I think (not sure) the ESC needs the better cooling than the motor and the way it looks is the rudder is cooling the ESC. Caution I have run into a heat increase problem when I add left trim to the rudder. When I am spinning a big prop trying to make the boat run straight without shimming the strut. It reduces the water to the rudder pickup hole and does the same for big left hand turns. I would simply switch your hoses an cool the ESC from the transom water pickup which is a nice idea BTW. Since I have moved my water pickup to the bottom of the rudder.
My 2 cents
Do It Like You Mean It .....or Don't Bother
