Results 1 to 2 of 2
Thread: programming 35 amp turnigy esc
    Aug 2013
    NY
    119
    Default programming 35 amp turnigy esc
    cant seem to get programmer to power up followed instructions and programmer is dead. Any help would be greatly appreciated. Ran boat this weekend and then on second battery boat died in water, Let everything cool down and tried again and motor was making screech sound and very hot. order another but I was thinking maybe esc was not programmed correctly and caused motor to fry .I am a newbee and really could use some help getting these problems corrected.
    Sep 2013
    IN
    848
    You have to plug in the motor to the ESC and then to the programming box, lastly to the battery, it should then power up. I've had a screeching motor too, which resulted in buying a replacement. Hope this helps.
