Results 1 to 13 of 13
Thread: Motor for sv27??
    wa
    1,384
    Default Motor for sv27??
    I am going to have to purchase a motor for my sv and was curious if I could get a little more bang for my buck by getting a feigo. I just wondered what size in that line would the stock mount hold if any. winds arent an issue now I just didnt know if I should go all the way with xl series? thanks
    southern maryland
    321
    if you devcon the wood inside you should be fine.. im not sure what motor would be comparable, but if you need an sv27 stock motor, i have plenty!
    restoring the collection
    Nj
    4,735
    I hear this is the best and safest upgrade avalable.
    SV motor
    wa
    1,384
    Yeah I still need that other stuff we spoke about. Ill send ya a pm probly Fri. Payday. Im really building the sv for the little woman so Ill have someone to blow away with my originall build. I need to keep it farely stock and cheap.
    wa
    1,384
    Do you guys like the 5 minute or 30 minute devcon?
    Nj
    4,735
    It depends on the use. For structural apps I use the 2ton stuff. for just holding an object down the 5 min is fine.
    Baltimore
    623
    I have been running a 12L motor using the stock SV ESC on 12 cells for about 6 months with no problem at all and it hauls.
    wa
    1,384
    using stock motor mount?
    Quote Originally Posted by SJFE View Post
    SV motor
    will that motor work with the stock esc?
    Quote Originally Posted by H&MWill View Post
    What motor are you running? Do you have a link? thanks
    Baltimore
    623
    It is a 12 L Feigo from OSE. It works with the stock mount and ESC. I have had great results with this setup.
    The 12L feigo say it will only handle 6-12 cells. I would like to use 14 (since I have sets for that), would it be ok to do that, or would I have to get a XL? Would the stock esc work for the XL?
    Baltimore
    623
    The stock esc will not handle the XL motor. You should ask Steven at OSE if the L motor will handle 14 cells. I think it will but ask him just to be safe.
