New Revolt......
5/32 Cooling lines, use 3/32 line as a collar(band) to make a tighter fit.
OSE Water Outlet and Bulkhead Fitting
OSE Carbon Fiber Battery Tray, you can change the hold down Velcro straps.
Reinforce Hull extra 1" wide med F/G under tray.
Pulled foam block from Bow, added pool noodle.
Prop X442 spare X445 (worked to be a M445) Both B/S by Chris Hoffmann(Dasboata)
Up-Grade OSE Flex cable 150x 3/16
Dinogy Batteries 4S 5000 65C
Will be running P-Limited Dist. 9 NAMBA (Hopefully I can still drive)
