Removed the stock battery tray it was Cracked/Spilt, replacing with Fiber-Glass Tray. Question any easy trick removing white Adhesive that held the battery tray from factory?
Not going to Carbon Fiber hull, want to run two 1 1/2"x12" wide med weight F/G cloth , Above new F/G battery tray and between the strakes. Pulled Foam from bow, going to use pool noodle.
Any help would be appreciated.
Jim
Question: I've never worked with Caron Fiber, will Z-poxy finishing resin work , Do you scuff the shinny area on carbon fiber when you placing it on the resin?
Might use a Carbon Fiber Battery in the Revolt instead of the F/G Battery tray ?
