Hi Guys
Boat : Radtek/Hpr 2.33m
Motors: Neu 2230 1y 725kv
Esc's: Schulze 40.334WK
Batterys : 12s setup each side
Im at the stage where the boat is complete and i just need to purchase batterys.
Ive been speaking with Mark on here about his Dinogys and had planned to buy packs off him.
I like what i hear about them so figure there the way to go..
I was going to buy 8 x 6s 6000Mah 65c packs
or even 6s 5000mah 65c packs not 100% yet
So 4 each side and obviously each pair in series to give me 12s 2P 10,000 - 12,000 Mah
Dinogy 5000mAh 6s 65C
Specifications:
•22.2V
•Max Charge Rate6C/36A
•Pack Weight 825
•Pack Size 54x48x160mm
So 8 x = 6.6kg
But have since found some packs from another reputable brand that i use in my Electric Helis that are now doing
6s 10,000mah 60c packs.
So i could just run 1P but still retain the same MAH.
Revolectrix 10000mAh 6S Lipo - Diamond Label -
Size: 104mm thick x 44mm W x 152mm L,
Weight: 1575 grams, Ratings: 60C. Cont. 120C Burst. 6C Charge Rate
4x = 6.3kg
So my Questions
Is it pretty much the same deal?
Or is it just better to have power coming from 4packs as opposed to 2?
The wiring with the 1P setup will be alot shorter considering Schulze say to count every bit of wire from esc to cell tab.
Cheers
