Can anyone point me to a Prop Anvil?
Check out the posts by D.Smock in this thread.
https://forums.offshoreelectrics.com/...ead.php?t=3223
Do you know if they make it for a 1/8 or 3/16 shaft prop?
I only saw the 1/4 shaft version
I talked to Brian Buaas a couple of years ago regarding locating a prop anvil. Brian said they were not absolutely necessary and he showed me one of his secrets. A simple pair of slip-joint pliers with one jaw ground down to a semi-spherical shape, and the other ground such that there are no "teeth" on it. Grab the part of the prop you want to tweak, and bend away.
The prop anvil can make it easier for bend but as Doc says not nessicary.
There is a guy over at Jims boat doc that sells a real nice set and if I am correct it will fit all three sizes, and a really nice price also...
Iiiiinteresting....
no anvil and pliers you say, eh Doc?
David, can you tell me who it is?
Voo Doo props here is the link to the thread here is here email. voodooprops.com. Their's seem to be better tham some of the others I have seen
