Results 1 to 3 of 3
Thread: Esc problem
    Jan 2010
    nj
    46
    Default Esc problem
    So i have just purchased 2 new 4s turnigy lipos thinking it was a bad lipo. I have 2 leopard motors and 2 turnigy 120 esc's.The problem is that when i give it throttle the one esc dosent spin up a the same time like its on a delay for a second. When i put it in the water it quickly looses all power on that esc. Ive switched sides of the motors, lipos, and esc's but still does it on the same esc. Do i need a new one?
    Oct 2010
    tx
    4
    Most likely you just need to recalibrate your escs. Go through the settings make sure they are set up the same then follow the esc directions for setting the stop position ant the full speed position on both escs.
    Mine did this a while back.
    Sent from my SCH-I535 using Tapatalk 2
    Jan 2010
    nj
    46
    Hey bud, That sounds like a great plan!!! Waiting for new props to come in. Ill try it soon as they do. Ill let you know. Thanks!
