Page 1 of 7 123 ... LastLast
Results 1 to 30 of 208
Thread: 1/6 scale Jetsprint boats and 30mm Jet drives
    May 2010
    NS
    237
    Default 1/6 scale Jetsprint boats and 30mm Jet drives
    Hi Guy's,
    Not too sure if this is the correct area to post this thread but i have bbeen working on production of a 30mm Jet unit, it has a 30mm dia Alloy impeller, ABS body, Trimmable Nozzel. This is a Mixed flow jet and has a much better performance than the Graupners and KMB units out there.
    I am looking at releasing the units within the next 6-8 weeks as i am now waiting for the injection molds to be completed, They will also have the availability of being transferred into a 2 stage unit with only an addiition of another set of impeller/ flow straightener and a connecting ring.
    Also due to be released will be 2 types of hulls to suit the jet units , they will be a 1/6 scale 650mmm long jetsprint, and a 850mm long Marathon river race jetsprint hull, these hulls will be vacuum formed ABS, construction will have to be done by the purchaser, pictures of the huls will be a few weeks away, i have attached some 3d prints of the jet units so you get a look at them.
    I haven't set the price in yet but thinking somewhere around the $130-150USD ea? Hulls will be around the $130USD Ea mark.
    Regards al Mick
    May 2012
    940
    Mick,
    So glad you are working on a pump. How efficient will to be? Will you be listing the thrust, motor used, ESC and batteries used in your testing? Can't wait for a good one that everyone can run.
    Good luck.
    Mike
    Do It Like You Mean It .....or Don't Bother
    Jun 2008
    OH
    2,345
    Pump looks awesome. Price seems a bit high for ABS hulls?
    May 2010
    NS
    237
    Quote Originally Posted by Mike Caruso View Post
    Mick,
    Good luck.
    Mike
    Hi Mike,
    I'm not too sure how to measure the thrust, but i will certainly try my best to report on everything about them once they are ready. I was going to use a Leopard 4074 1600kv motor with a 120 amp esc on 4s lipo. These units have been a work in progress for over 10+ years and have only become a reality now. The performance will match the effeciency of the larger cousins of the Swashdrives and Jettecs, as it is a mixed flow pump with overlapping blades and the trimmable nozzel. I am doing a initial run of 1000 units.
    As for the price on the hulls it isn't locked in concrete yet but you will get a Alloy rollcage, SS jetunit cover, and 2 prepainted drivers, So it isn't just the bare hulls, i will offer infused carbon hulls at a later date but that is dependant on the demand.
    thanks for looking guy's, i will be updating this thread as the news becomes available
    Regards Mick
    Jun 2008
    OH
    2,345
    OK now that sounds more like it!
    I will be watching for updates. Always wanted a jet boat.
    7,631
    Mmm,good work on the jets. I had done a load of research in hopes of building my own many years back. Glad to see fruitition I imagine Mick . I shall be very interested as I love my NQD(bit small) and have a 28mm in a scratch built flatbottom( my avatar). I look forward to the release and pics.
    I don't know if a 120 will quite be enough though you shouldn't see spikes so much with a jet it does take a greater steady load to maintain pressure. I've been meaning to put the ET on the NQD.
    Great work,Shawn
    1,431
    Looks awesome. My first boat was a jet drive but the hull was too big for the drive. I've been wanting to build my own drive for a while now but don't have the time, money or knowledge really. I'll be impatiently waiting for the test video.
    May 2012
    940
    One jet unit should be able to be tuned for many motor / battery combo's. Just like real jet pumps can work with 300 HP or 1200 HP and more engines by changing the impeller. Key is us RC guys we will be needing different impellers as one size does and will not fit all. Check out this guy who has lived with the real jet boat pumps and is a guru after many years http://hi-techperformance.com/ nose around in his tech stuff.
    Great guy.
    Mike
    May 2010
    NS
    237
    Hey Guy's,
    Thanks for the feedback guy's, it is most appreciated, and i will sure to be loading the first testing video once i get the time .
    Mike , at the moment i will only be releasing one impeller with it but i will be releasing different pitch ones at a later date, but for now i will be doing all the expensive research into motors and will report back with the best motor to suit this drive/impeller setup.
    If you have any questions please ask away.
    Regards Mick
    1,431
    May 2010
    NS
    237
    Not too sure if i follow you,
    Jet units are still a little while off, the impellers will not be ready untill after the 25th so will not be able to put in an update untill after then, please remember i am making 350 jet units and about the same in boat hulls.
    As i get some more updates i will sure to be updating here
    regards Mick
    May 2010
    NS
    237
    Mike, the jet units have already been tested, the testing I have to do is with the hulls, that is why I have a 3d printer, the jet unit I have printed out is not a fully functional unit but is enough to prove the design, and I have been playing around with impeller/ flow straightener designs for the past 10 years.
    I really do not want the customer to be scape goats and work out any issues, this is simply not good business.
    On another hand I have also been playing around with designs for a race hovercraft, the intent is use really cheap electrics and race them on the tidal sand flats round where I live, but also to provide a inexpensive but good quality entry into hovercrafts. I am going to vacuum form the hulls out of ABS.
    Warm regards Mick
    May 2012
    940
    Cool I had to go back and read that you have been playing with the jet pump for ten years.......Best Mike
    1,431
    Is that the 25 th of this month? Got a hull I wana try a jet drive in, was thinking a 29 mm graupner at first but then I remembered these.
    May 2010
    NS
    237
    Hi Mate,
    Yes that is the 25th of this month, but that is when the impellers will be finished being machined.
    Got the first trial run parts of the jet units, got a few modifications to get done but it will not be very far off at all.
    By the way, good luck getting a Graupner unit, as Graupner has folded and there will not be any more units or parts available soon. I will also have the hulls available soon, finished the bottom half of the mold, just got to do the top and the cowl then I will be making these in fiberglass , I will be supplying 3 different hulls, one that is about the 500mm long, 650mm long (Jetsprint hulls) and another that will be a Marathon river race jet boat 800mm long.
    Warm regards Mick
    1,431
    You are right about the graupner drives, didn't realize they went under. I know a guy that makes replacement parts, or at least he has made a part for me when I still had my 29 mm drive. Are you accepting pre orders? I'll buy one of your drives and do my own R & D on motors if you get one put together. Maybe you could cut me a lil break on your prototype and ill be sure to give you feed back.
    May 2010
    NS
    237
    Quote Originally Posted by TheShaughnessy View Post
    Hi, Thanks for the offer, and may take you up on that, as long as you will put your honest findings on the pump here for everyone to read.
    I am still waiting for the impellers to be finished, plus the finalisation of the injection molds will hopefully be done very soon.
    Will keep everyone updated as the progress continues.
    Regards Mick
    May 2011
    332
    Iv'e been looking for a pump also , looks GREAT . Mike
    WA
    8,335
    Quote Originally Posted by mickieb49 View Post
    Hi Guy's,
    Regards al Mick
    Mick,
    Count me in! I've been wanting to put together a JetSprint for some time, just for the fun of it! Let us know when, where, and how much.
    Darin E. Jordan - Renton, WA
    1,431
    Darin we should make a NAMBA class and course for jet sprint. It's been a dream of mine for years. Now if we could get a quality pump at a decent price.... Money is burning for a jet pump . Have a cheap hull with a shallow vee waiting to experiment with.
    May 2010
    NS
    237
    Thanks for the keen words guy's,
    I have to wait for china to get back from a puplic holiday before i can get some progress updates from the manufacture of the pumps, also get a transformer for my vacuum former.
    Plans for the jetsprint hull and the Marathon river race jet boats are getting closer too, hopefully i will be able to cnc the plugs out in the comming weeks.
    I have also got hold of a supplier that i am a wholesaler for now for the ESC and motors, Just wondering if it is actually worth putting this option out there for everyone? Also thinking on more like the $120USD each for the pump , and around the $130USD for the hulls, kit for $299 ( this will include the Pump, Hull, Rollcage ( CNC fittings) , Dummy drivers, stainless pump cover, Uni joint for the drive shaft.
    I do really appreciate everyone's patience, this has been a long winded wait, hopefully it is worth it.
    Warm regards Mick
    7,631
    This all sounds great Mick. Look forward to it coming together.
    1,431
    Got 120 ready to go for the first one
    1,431
    Any updates?
    May 2010
    NS
    237
    Hi, no sorry nothing yet, still waiting for the impellers to be finished, also waiting for the final changes I had to make with the injection molded parts.
    I am so sorry for the long wait, unfortunately china had a public holiday for that past week and that really buggered me up.
    Again I am sorry for the wait, I will do my best to make it up .
    Regards mick
    1,431
    Don't stress it. I will patiently wait.
    May 2012
    940
    Hi Mick,
    I see it is coming along very nicely. I have a question I know you have been testing for ten years off and on. I wonder what size motors and cells you have used? Juts tring to get an Idea of power required to turn that impeller?
    Best,
    Mike
    P.S. Like TheShaughnessy says 'Don't stress it. I will patiently wait.'
    1,431
    Hey mike, mic probably has a better answer but if I can get my hands on one im going to power it with a 1800 kv proboat, I'd prefer to use a 1500 kv but the wires on the one I have are kinda sketchy, got it pretty hot a few times.
    No idea on how this one will perform, and I feel bad even comparing it to a graupner drive ( because it seems to be a much better design. ) but that's all I have to go off. My personal experience/ observation with the 29mm graupner drive was that one you got to a certain rpm it was maxed out. Once I hit 3/4 throttle I was pretty much at max speed. I could squeeze the trigger more and would hear more rpm but not see any increase in speed. A few of us on RCU agreed the max effeceincy RPM was right around 21,000. I don't think we were using stock drive lines though. I know I changed the stock tubing for one that fit a .150 flex with a 3/16 stub. I didn't use a Teflon liner, but if I were to do it again I definitely would because I never could keep the water out and I'm fairly certain it was getting force up through the drive line. My original intent with that was to be able to use a drive dog and be able to use a Cu prop but wasn't able to because I couldn't fit the drive dog, prop and a nut between the guide vanes and the new tubing so I ended up taking the threaded insert piece from a stock prop that got chewed up and force fitted it into a 3/16 bore Cu prop. That ended up working pretty good with a s220 I had. it was a lil banged up so I figured it wasn't much of a loss if it didn't work out. I put it on a flex ran it through some brass tubing with some grease then clamped that down with my rotary tool hooked up to the flex. Spun it up and ground it down until it fit.
    The two pumps use a completely different impeller design. The graupner impeller is just a 2 eared surface piercing prop design it isn't really an impeller at all, more a prop in a jet pump, mics design mimics a true impeller design found in full size jet pumps so his may not max out like the graupner.
    Here is a pretty bad still camera vid of a set up I used to have.http://m.youtube.com/watch?v=2Ci9MCl...ture=c4-feed-u Pretty sure it was the stock plastic prop here. Not a good hull and pump match (didnt know any better at the time, but it was entertaining. Using a blue can aquacraft 3656 and 45 amp esc from a super vee on 4s lipo ( might be 12 or 14 cell nimh in the video. It was a while ago). Started out with a graupner speed 600 ( I think) and 7.2 v nicad stick packs it was pretty slow. Added a couple cells and it was better but run time was horrible. Sat on a shelf for years before I got a hold of it and revived it with a new power system. http://m.youtube.com/watch?v=2Ci9MCl...ture=c4-feed-u
    That turned into a tangent. Doesn't even really answer the question. I will ( assuming I get one) run eagle tree on the 1800 kv set up I plan to try with it and post the graphs. Should give a pretty good idea own how much power is needed. I never had any heat issues with my previous set up running 10+ min at a time but I was usually messing around in moving water and rarely running WOT.
    May 2010
    NS
    237
    Hi Guy's,
    Like what was previously mentioned, i will be using a 1800kv 4072 leopard motor with a 120 amp swordfish esc on 4s 5000Mah 40c battery, this setup has been good to me with no overheating or problems. That was with the Graupner units and Kehrer ( highly modified, see also my youtube vids)
    This unit like the tru Hamilton and Scott jets is not intended on trying to spin it over about the 25k mark, if you try to do that you will start getting a hydraulic locking effect and basically the effeciency will drop off. All too often i see people putting 4000kv motors into those NQD jet boats and running them on 3s and even 4s, then wonder why theu have problems?????
    This is a mixed flow pump and like Shaughnessy has said is a very different type of pump as compared to what is basically a propeller wrapped up in a inlet ( graupner and Kehrer)
    I will be trying lower kv motors but i believe the 1800kv to be the best.
    I am hoping to be able to share some more pictures of the new hulls very soon too.
    Here is my youtube link:
    http://www.youtube.com/watch?v=0hJ7ex4OGaM
    Regards Mick
    May 2010
    NS
    237
    Greeting lads,
    Just a little update, i have had some not so good news, the manufacturer who was doing the impellers has informed me that he may not be able to do them for me as the CNC mill he has is out of action, aparently they have been waiting for a part to get there from the US for over a month so far, i am hoping to hear back from him today or tomorrow, if he cant i do have another manufacturer who can get them done , just a little dearer ....
    I should also be getting the first of the redesigned injection molded bits at around the 25th of this month, then if all is well then we should have the injection molded parts within a week following,
    Still also waiting to get another Router bit to finish off the plugs for the hulls.
    Thankyou everyone for their patience, i think everyone can appreciate the time and effort ( and off course $$$) that goes into manufacturing these in a large scale.
    Regards Mick
