Results 1 to 3 of 3
Thread: gutted motley crew
    Feb 2013
    WA
    179
    Default gutted motley crew
    I wasn't gonna do this until the race season ended but I had a guys sponson punch a hole in the side of my boat and decided it was time to do this. I cut out the tub and went through it properly. Wow, what a difference it made, this went from a sport boat to a full on race boat. I can easily outrun any other cat in the class including four other mean machines.
    Dec 2009
    on
    2,187
    How much flex does the deck have now that you have removed the tub? When I did the last rebuild of mine I thought about doing this but was worried that it would fall apart or cave in during a blow over! Not exactly the thickest layup for these hulls.
    Looks good, I installed some wooden rails in mine and ditched the stock motor mount, also moved the motor towards the back of the hull, made a huge difference, more room to move the batteries now to dial in the CG, also made the bottom of the tub a lot stiffer.
    Also swapped in a SV27 rudder with watercooling, I run both pickups and cool the motor and esc separately, ran the new line in the old exit, installed two outlets in the side of the hull so I can see the water exiting.
    Fun boats once you get them dialed in.
    Oh ya also put a layer of 'glass on the inside of the hatch, replaced the plastic braces with some carbon fibre rod.
    Feb 2013
    WA
    179
    I like the idea of the sv27 rudder, I also move the cooling exit to the side. I didn't no tice a significant loss in rigidity after the tub was out, I've endowed it multiple times since I went through it and its still here.
