Results 1 to 7 of 7
Thread: Servo size and motor timing
    Apr 2013
    QL
    241
    Default Servo size and motor timing
    Just wondering what servo torque you guys are running, mine gave up today and just seeing what others use. It's for a tunnel setup as inboard, also a cat both in the 1m (40 inch I think). It's been asked a million times but just checking, got 2 motors TP Power one 6d the other 7d so timing set 0-10?
    Apr 2011
    5,666
    I use Futaba http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML on my VS1 Tunnel, I had no choice, the boat was set up for a low profile servo, it performed flawlessly, but time will tell if it lasts. So far so good. For my two other tunnels I used Futaba S3005, in fact I use that on all my boats up to 33''. On my DF Sniper 45" I have a 1/4 sized Futaba servo. Don't remember the exact number. My tunnels are all out board and they demand a lot of torque. I have been recommended to this duo here at OSE:http://www.offshoreelectrics.com/pro...od=ker-fs5617m, http://www.offshoreelectrics.com/pro...od=ker-ft5515m, they both have MONSTER TORQUE ratings! I must say upon seeing one first hand, I was impressed with the built quality at least judging from the outside, unfortunately I haven't had a chance to use it, but the ratings by the maker is impressive and the price is reasonable.
    I put a Hitec HS-645MG just the other day into my yet to maiden Insane 34 mono.
    I like to have my servo torque rating at no less than 120 oz-in @ 6v, I couldn't care less with the speed, it is not a car, I think in the water that is of less importance, as far as I am concerned.
    "D" wind motor timing is typically set low. 0-10 is good. Depending what choice your ESC gives you.
    Apr 2013
    QL
    241
    I run the hitec 5646 WP in my cat and spartan they 179@ 7.4v wasnt sure if I should go more torque (This tunnel is inboard so doesnt have to turn motor and prop) Those fitec have some serious torque and they are great price. Only thing i want to run this boat tomorrow so its kinda what ever the LHS has (unless OSE does overnight postage to AUS ) I do like the 5646 being waterproof.
    Apr 2011
    5,666
    The 5646 is very good, only problem I had one time was that its case is just a hair larger than the average standard sized servo. Good luck at your LHS!
    I am surprised that the low profiled Futaba had no trouble turning the OB though, the tunnel originally was fitted with a $15 low profiled servo, http://www.hobbypartz.com/33p-solarservo-d770.html but was making noise and I didn't want to cheap out so got a name brand, lol...
    I have a feeling that the $15 servo is just as good if not better: it has more torque ratings, these days everything is made in China, so I am just flushing my hard earned money down the toilet...
    Aug 2010
    uk
    2,887
    D wind low timing 0-5 degrees, Y wind medium 10-15 degrees.
    Apr 2013
    QL
    241
    SF give low/med/high auto then 2,4,6 all the way to 30 lol. Will just either set to low or 4 to start with.
    Apr 2013
    QL
    241
    LOL turns out the servo is fine just the servo extension wire has the red prong missing... Still it's only a tower pro mg995
