Here's my most reliable boat i've ever owned, up for sale.
Its a Shockwave 36 by Pro Boat
Boat is RTR
i bought the boat used, had the dynamite .32 modded by AB Mods.
Engine has right around 2 1/2 gallons through it.
Boat has been wrecked. I had a run in with a drain tile from the other side of the pond. Ive repaired the areas, they just are not finished. What was damaged on the hull, does not mess with the boats performance at all. This boat runs very nicely!!
Hull, Hatch, and the inside of the hull are all in great shape
I moved the 6v receiver pack to the front of the boat in front of the fuel tank. Battery is slid into a piece of foam noodle. Nose of the boat has been stuffed with foam noodle also. Radio box and tray are in great shape. The steering servo mount on the radio tray was cut to a larger size so i could run a little bit bigger servo then the stock JR Z270. Right now the boat has a Z270 for throttle and a MG995 for steering. Boat also has a Futaba R603FF Fasst receiver. Im including a nearly new Futbana 3pm 2.4ghz Fasst radio. If the buyer does not want the Futaba, i will throw in the stock radio for this boat for free.
I added Aqua Crafts header cooling coils to the shockwaves header.
The rudder and rudder stand off are both from Aeromarine. The rudder is polished but could use some TLC with some metal polish. The prop is a Sharpened, Balanced and hand polished X645. Boat currently has 2 water pick ups, so if you feel like running one of them to the engine and the other to the header, its all set up and ready to go.
Im also including a few other items.
7 brand new MC8 glow plugs
2 NIP Rossi R4 plugs
2 spare hose clamps
30 min epoxy kit
brand new tube of 2 ton clear weld epoxy
Brand new can of Corrosion X, can was used 1 time on a 2.4 receiver
Prather cable grease
radio box lid tape and hatch tape
4 glow igniters
new package of Dubro Nitro line, 2 ft
4ft of water cooling line
glow igniter charger
receiver pack charger
nearly new OFNA 1600mah 6v flat pack
Orion 6v 1600mah flat pack
spare stock engine mounts
bottle of after run oil and a surenge
2 spare flex cables, 1 brand new, 1 nearly new
stock rudder stand off
hand crank fuel pump
spare radio box cover
Futaba R603FF receiver that needs repair
Boat also comes with a spare unfinished x645
Im also including an assortment of screws and nuts, pretty much anything else that i come across will be included, Im also including a OFNA fuel bottle.
Boat is ready to get wet
ive never had a problem with it taking on water.
like i said, this boat runs very well
im asking $260 plus shipping for what is pictured and everything else i have for the boat
I'll take $210 for the boat plus shipping minus the futaba radio gear, and i'll throw in the stock JR radio for free.
Pictures-
i accept paypal and money orders
Feel free to contact me anytime with any questions regarding this boat.
Thanks!
-Sean
