Page 1 of 2 12 LastLast
Results 1 to 30 of 38
Thread: Delta force 41 mono or delta force 36 explorer
    Mar 2012
    Qc
    186
    Default Delta force 41 mono or delta force 36 explorer
    Hi Guys, I got a spartan for now , but i want to buy a fiberglass boat , because i want a more stable boat and of course been able to repair it !! I first bought the spartan because i was a newbie in FE boat and already got some traxxas trucks , that s why i began with it .
    Now i m looking for a better hull . I m not a guy how want to break speed record , just want to bash and have fun! I really like to drive in choppy water and jump wave , doing turns .....
    I was looking at the OSE and been hook on the 2 model , the delta force 36 explorer cat and the delta force 41 mono and i can't decide myself !!???
    Do you guys got some experience with one or the other and can give me some advise and tips to decide me ?
    I got in stock a leopard 4092 1390 kv , t180 esc , 4 dinogy 3s 5000 mah 65c to put in it !!
    Thank's for your help !
    Aug 2009
    mi
    344
    the mono is your next boat,the cat tips over very easy when turning-you will be ok jumping waves with the mono!
    Mar 2012
    Qc
    186
    Quote Originally Posted by bozo586 View Post
    Thank's ! Does the mono from delta force seen to be more stable than the spartan hull ?
    Aug 2009
    mi
    344
    the delta force mono is bigger by 5" and is a lot stronger build wise. better in my opinion all around,for what you want to do.
    Mar 2012
    Qc
    186
    Thank's !! For sure , first the DF 41 mono is fiberglass , better than abs plastic, and the V seen to be better for stability on higher speed run . The Cat , IMO and what i seen on youtube , they are a very stable boat for very high speed straight , but for turning in wave ??? I don't know !! I think more to go with the mono !!
    I appreciate that you take time to answer !!
    Sep 2010
    nj
    4,289
    The pursuit is a nice running hull to,
    Just it is only 32".
    But so far I like the way it rides,
    I still need to do some testing where the jet ski's run and in some real boat prop wash.
    Than I will take some video's of it's handling in it.
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    I sub to your channel last week and check some of your video !! The pursuit seen to be very stable in choppy water , it run like on glass ! You said is only 32" long , but the wide is very large and give it a stable run !!
    Do you think the hull can handle a leopard 4092 1390 on 6s ?? Cuz , i got one in stock with the t180a , so i want to put it in my next hull ?
    Did you try it in bigger wave ??
    Thank's for your comment !
    Sep 2010
    nj
    4,289
    It should be a pretty good runner,
    You will be at 30858 rpm unloaded.
    1390kv * 22.2 volts = 30858 rpm.
    Hear some one that may have run that setup all ready.
    https://forums.offshoreelectrics.com/...walking-advice
    Also check this out to.
    https://forums.offshoreelectrics.com/...uit-Miss-Geico
    And not sure how this build will work out.
    https://forums.offshoreelectrics.com/...uot-cyberstorm.
    ? ONLY IF THEY WORK
    Sep 2010
    nj
    4,289
    Next video's should have some better chop to try in,
    The video you saw was in 30 mph wind gusts on that day.
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    I check the thread link you give me Lenny , very interesting ! I drive my boat in the st lawrence river , that 's why i look for a boat close to 40" !
    Nov 2008
    Ql
    3,169
    Banzee.
    I run a Nue 1527/1y (1250kv) on 6s in a 41" Osprey. They say is's a copy of the 41" Delta Force. At least the bottom half.
    It runs pretty well in choppy water.
    Mar 2012
    Qc
    186
    Quote Originally Posted by 785boats View Post
    Banzee.
    The 1527 is more powerfull than the leopard 4092 ? Or almost in the same range ?
    Nov 2008
    Ql
    3,169
    Yes. More powerfull & a lot more efficient. Won't get as hot with the same size props.
    I run a 447/3 blade & a 450/3 blade prop. Every thing is cool after a race.
    Mar 2012
    Qc
    186
    DO you have torque roll problem with that motor / prop setup ? I don't think so cuz you used it !! Do the 3 blades work better on that hull than two blades ?
    Nov 2008
    Ql
    3,169
    No torque roll problems. The 41" hull is stable enough. I prefer 3 blade props on all my mono's. The boats handle better in my opinion. A three blade prop is usually a bit smaller in diameter than the two blade prop you would run.
    Sep 2010
    nj
    4,289
    I like the three blade to on mono's,
    Because it helps with torque roll problems on mono,
    Especially with very narrow hulls like my Rio ep and p1 kos.
    They just look like they run so much smoother with the three blade props to.
    ? ONLY IF THEY WORK
    Jan 2011
    PA
    1,141
    Anybody ever put a flood chamber in one of these 41's??
    Mar 2012
    Qc
    186
    How it handle in turn , do the 3 blades make some cavitation , or it hook up and make turn ?
    Mar 2012
    Qc
    186
    Do you put your prop more in the water or it is the same installation like a 2 blades ? I ask because i tries a 3 blades on my spartan and got a bad result , but i think is the v hull design who make it not working properly on it , but the pursuit and DF 41 have not the same v hull design , i m sure it make a difference for the prop !!
    Sep 2010
    nj
    4,289
    I just put it on and run it and see how it rides,
    Than if it is not riding the way I like it.
    I will make some adjustments.
    And the three blade work for me fine in the turns at good speeds.
    Are you talking turns for racing ?
    Or sport running and hairpin turns and bashing for fun ?
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    I talk about bashing and sport driving , like in choppy water and jumping waves !! IMO , the 3 blades will help keep the forward motion because it got more surface blade to push the boat !!
    Sep 2010
    nj
    4,289
    Hear is a V mono I thought was very cool,
    And than I started modding the 36"shockwave you see in my video's.
    It is no where as nice as this one but will do for now.
    https://forums.offshoreelectrics.com/...arette-40-quot
    https://forums.offshoreelectrics.com/...tte-40-quot-6s.
    These came out nice to in the end.
    https://forums.offshoreelectrics.com/...tup&highlight=
    https://forums.offshoreelectrics.com/...20.&highlight=
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    " superb video , this a good way to have fun with an rc boat !! That boat handle very well in the waves , awesome !!!
    Your shockwave run very good and very stable !! What is the setup on it ?
    Sep 2010
    nj
    4,289
    Shockwave is all stock hardware but modded a little,
    And is running on 4s with 4074 2200kv motor and a 120a seaking esc with some added caps and a x446/3 prop.
    Top speeds gps at 45 mph,
    It was just stuff to try in it I had laying around and it runs pretty good with some scale looks,
    But I will paint it and redo the setup down the line.
    I may try a T600 1400kv outrunner in it and see how it does and sounds.
    Pictures of 36 shockwave 001.jpgPictures of 36 shockwave 002.jpgPictures of 36 shockwave 008.jpg36 Shockwave mod. 007.jpgphoto(6).jpg
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    That's really a good boat and the 45mph mark it is a very good speed for fun !! I did a little look at the outrunner t600 , it is a helicopter motor ?? or i saw the wrong one !!!??
    Sep 2010
    nj
    4,289
    Yes it is a heli motor,
    And it is the same one that is in the Cigarette 40" video's I posted.
    Post #22
    This is his setup in the Cigarette 40" on 6s.
    http://www.hobbyking.com/hobbyking/s...dProduct=12442
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    Ok , does the heli motor help for torque roll or chine walk , or it change nothing , and are more powerfull than the rc boat motor that we put ? Because , it is the can who turning , maybe it got more torque !
    Sep 2010
    nj
    4,289
    Not sure on that,
    But the motor has a lot of power and torque.
    Plus they sound pretty cool but can run a little hot with no water cooling,
    I was thinking of a modded motor mount for a way of water cooling them.
    ? ONLY IF THEY WORK
    Mar 2012
    Qc
    186
    For sure with the outside of the motor who turning , you have to put a motor mount with a water cooling in it so it can be running more cooler .
    9,401
    I'm going to try some old packs (10s1P), suppo 6-11S 80 esc with the T600 880kv both in a heavy 31" cat and in my light 40" mono. I have water cooled motor mounts from China @ $15 a piece or less made by Vantex.
    They have then in blue, red and clear anodized. They are an odd 3.5 approx wide with sides on.
    On second thought I might just stay on 5S2P and the 1400kv vesrion. 32,000rpm is quite high. On 5S2P 5000's you can swig up to a x450 for 6 laps at about 55mph... at least that what my Promise hobby 31" heavy cat was doing a few years ago...
