Results 1 to 27 of 27
Thread: ul1setup and prop tuning
    Jun 2013
    sc
    13
    Default ul1setup and prop tuning
    Today was my first time driving this boat but after reading many post on here I had already upgraded to a 120a turnigy esc and set my boat up on 1 4s 5600 mah pack crossways in front of the motor. I have the battery as far forward as I can get it under the top cover my cog is around 1.5 inches behind the back of the pontoons. I'm running my stock prop at 7/8 dep and 1 degree down with air dam. With all that being said I had a accident today where my flex shaft broke off and I lost the whole end of the prop so I figured it was time to upgrade. I ordered upgraded flex shaft, bushing , grim 4057. What do you think ill need to do to get me close to a good starting point on my prop depth and is there something else I can do to settle the chine walking down? I also want to know what do you do to set up your turning fin to keep your boat more stable in the corners????? Any help is appreciated I've looked all over this forum for this info including the stickies and no luck please help! Thanks Jeremy
    Jul 2010
    Tx
    175
    With the set up you've listed...to get on plane with that prop..start prop depths at 1 1/8 in. - 1 1/4 in. and see what works.
    Jun 2012
    MA
    1,876
    With 40/57 you'll see 50, but that prop NEEDS to be balanced and sharpened, and it's a really tough one to do. Good luck!
    Jun 2013
    sc
    13
    Ha ha! Great I'm a complete newbie to boats and don't have a ballancer I guess I better order one of them and see if I can do this. Can someone show me a picture of a sharpened prop up close for reference please, thanks
    Jun 2012
    MA
    1,876
    I ran that prop with my strut all the way up. Mainly people bury the prop when the prop isn't b/s nice, to get it to hook up.
    As far as chine walk, you can try adding weight in the sponsons, cut an access hole and add weight. As far as turning, as with any hydro, keep the throttle pinned. Slowing down in the corners only makes sloppy cornering
    Jun 2012
    MA
    1,876
    I just did one last night, I'll post some pics shortly for you
    Jun 2013
    sc
    13
    Thanks I just watched some youtube video that helps a little, do you detounge these props?
    Jun 2012
    MA
    1,876
    Here it's hard to get good photos, but you should file the rear trailing edges flat.ImageUploadedByTapatalk1371392471.055502.jpgImageUploadedByTapatalk1371392482.547253.jpg
    Jun 2012
    MA
    1,876
    No these ones already have no tongue
    Jun 2013
    sc
    13
    Are both of these pics finished pictures?
    Jun 2012
    MA
    1,876
    Well, 90%. I will end up cleaning it up a bit with fine sandpaper, but for the most part yeah. Just want to run it today.
    The photos of course don't show the most important thing, that's the thinning of each blade over a large area of the blade. It's not about just making the edges sharp, it's about getting that sharp edge to have a slow, gradual transition into the blade. This one has titanium in it, it's like trying to sand a toilet! Good lord it's hard
    Jun 2013
    sc
    13
    I'm excited I'd like to see a little more speed out of my boat for sure but what kind of temps do you get out of your boat? I tossed my boat and ran for about 6 minutes yesterday wide open and was about 120 by the time I got it out
    Jun 2012
    MA
    1,876
    The 40/57 is gonna have higher temps, maybe 130 after 5-6 minutes. No biggie.
    You will see a dramatic increase in speed. These props will cavitate like crazy for about 3-4 seconds, then when they hook up, hold on, cause its gonna rip! If it doesn't catch you haven't done the b/s good enough. You could try lowering the strut in this case, but that's just a band aid for an inadequate b/s job
    Jun 2013
    sc
    13
    Thanks I'm going to try to do the job slow and take off material as slow as I can to get the right shape. Should I check my shape with putty so that I get the same shape on every blade?
    Jun 2012
    MA
    1,876
    I don't. Trust me you won't have any luck bending these blades even if you wanted to
    Jun 2013
    sc
    13
    Awesome I'm excited to get it on the lake! Wonder what it will do on 5 cells? :)
    Jun 2012
    MA
    1,876
    Quote Originally Posted by Jeremyfowler33 View Post
    Spend most of its time upside down if it doesn't go up in smoke first
    Jun 2013
    sc
    13
    I thought you could run the factory motor on 5s if you had a speed control that would handle it
    Jun 2012
    MA
    1,876
    Oh I missed you had the 120eac. Yeah you could try it, but the motor may or may not last long. The biggest problem is the ul1 at anything over 50 is just unstable. It will flip a lot. It's just not designed to go faster than that. Many have tried, but mostly the consensus is, out of control.
    Jun 2013
    sc
    13
    Thanks for the help ill try to get some video posted in a week or so of it with the prop changes and extra ballast in the sponsons
    Dec 2012
    NL
    7
    @Jeremyfowler33:
    Can you post me a link from the lipo you are using?
    I'm trying to get a decent 4s1p wich fits across the hull of the UL-1
    Thank you in advance,
    greetings Bastiaan
    Jul 2010
    Tx
    175
    I use Turnigy 4s1P 40C from Hobby King...they are currently out of stock.
    Dec 2012
    NL
    7
    How much mA?
    And is it Turnigy/ Flightmaxx/ brand?
    Greetz Bastiaan
    Jul 2010
    Tx
    175
    Turnigy....5000mah
    Dec 2012
    NL
    7
    sorry, i see now that you already have written that.
    Thanks!!
    Jun 2013
    sc
    13
    https://www.youtube.com/watch?v=Fq6e...e_gdata_player
    This is my boat on 6s 3300 mah packs.
    Jun 2012
    MA
    1,876
    Looks fast man, unfortunately over 50 with these boats, it's just like your vid, lots of flips. It's not about setup at that point, it's about the hull nit designed for the speeds
