Results 1 to 25 of 25
Thread: JetChopper30 on P-Power
Hybrid View
    ca
    6,963
    Default JetChopper30 on P-Power
    After setting, and currently holding the NAMBA P-Ltd Mono SAW record with my first JetChopper30 and building a "hotrod" version for Christian Z. in Chile, I decided to build a hotrod for myself. Having just decommissioned my Wacko dual rudder MM and having a spare Catle/Neu 1515 1Y 2200KV motor and a T-180, I set out to have some fun and add a litle bling.
    ca
    6,963
    I'm a fan of Spd stingers but I needed to shorten it to have the correct relationship with the Spd .21 rudder, which was shortened
    OSE tabs and large fins. (three holes for bling)
    To spread out the motor mount load, made some platforms for strength
    [I started with a Promodel motor mount that had the useless-for-inrunners front mount which recessed the motor bolts and made them hard to line up. Instead used an Etti center section which I added a top bolt to keep things lined up.]
    ca
    6,963
    3/8" brass tube for servo rod to pass-through without binding on full articulation
    narrowed the T-180 since it was getting placed next to motor in tight quarters - (hopefully one day the trusty T-180 ESC will have the water inlets/outlets going the same directions as the wires) Made a platform for the ESC to anchor it
    Favoring the "rear-motor/batteries-on centerline" design to keep weight low & centered (which I presume minimizes chine walk) (btw it worked) I made 3/32 birch ply battery trays spaced off the bottom to allow one-wrap velcro to keep batteries from strolling around and G/Flexed them in with holes to add epoxy strength/bond
    ca
    6,963
    The HRC water jackets come with small diameter fittings; replaced with larger ones after re-tapping holes
    same for rudder
    Waterlines short and neat inside
    Angled outlet makes output easier to check - less wind-shear effect
    ca
    6,963
    I'm a big fan of hatch retention. Tabs in front
    CF in back with tapered "locators" (CF can be tapped with threads!) BTW in this picture you can see the Etti center motor mount with easily accessible bolts
    Purdy 4mm anodized thrumbscrews through rubber grommets
    (somehow an FE30 picture snuck in & I can't figure out how to back it out )
    ca
    6,963
    Some Beauty shots with a big Thanks to MonoJeff for the nifty windshield
    Notice the ride-pad bottom.
    Hello Tony,
    I am testing with various strut/stinger length. I refer to John Finch's MONO MANIA. I believe 8.5% strut/stinger length is a pretty good value, reduce porposing. I have a rudder similar to yours. I modified the rudder to match the strut/stinger length:
    Longer rudder mount lift the transom in a turn.
    Rgds,
    Leo
    Oct 2008
    CO
    9,488
    Looking forward to the video on this one Tony!
    ca
    6,963
    Quote Originally Posted by Brushless55 View Post
    It's coming after the full build post is done
    Jun 2012
    MI
    1,509
    Very cool sir, as always. Diggin the tabs and thumb screws for the hatch....
    ca
    6,963
    Quote Originally Posted by Rocstar22 View Post
    Allows quick removal when needed
    IB34 P-Mono
    Works on Cheetah's as well
    Oct 2008
    CO
    9,488
    Looks and sounds great Tony!
    Mar 2011
    CA
    1,431
    Yep I was cruising along admiring the build and then a yellow Fe 30 pops up . Butterflies and nightmares.
    On a brighter note I'm pretty stoked on how my pursuit is running with some tired batteries , can't wait to pick up my dinogys. Not sure how long it will be before my new hatch gets here so I made one that looks good from 50 ft away. Also got a nice big rudder on there, huge difference.
    I'll be running p ltd cat next weekend, assuming the boat min. Is met. Could use a tune day before hand, water is usually flatter down there then when I run up here. Might have some free time mid week if you are gonna run at all before the race.
    ca
    6,963
    I wish my FE30 would pop up (the one that's on permanent display on the bottom of McKellips pond in Scottsdale ). There should be no problem making the P-Ltd Cat class minimum- only three boats are needed with the SCSTA -Boyd may show as well plus Stephen, Naveed and me.. Might have some practice time next week ; let's talk
    Quote Originally Posted by TheShaughnessy View Post
    Sep 2009
    HI
    1,679
    Looks good Tony. Sorry for the newbie question but who makes the hull?
  16. #16
    ca
    6,963
    Quote Originally Posted by BakedMopar View Post
    I have a direct connection with the maker in China. Might end up with a distribution deal.
  17. #17
    Hello Tony,
    I race NAVIGA style offshore, eq. to oval. My JC30 weighted 3490g(7.7lbs). Lift and speed were high. I will either add ballast or reduce the pad area. Will try add ballast first, make it 3595g(7.93lbs). The desigh was refer to Jim Russell's article "Why does a 'pad' make a V-hull faster?". Bigger pad not necessarily better. Depend on boat set up.
    Rgds,
    Leo
  18. #18
    Nov 2008
    Ql
    3,169
    Hi Tony/Leo.
    I wish I still had my JC30. But unfortunately it was T-boned by another boat & basically destroyed.
    Might have to get another one soon.
    Nice work, as always, Tony.
    Cheers.
    Paul.
  19. #19
    Hello Paul,
    Let me know before placing order. We will soon have the Lunar New Year Holiday.
    Rgds,
    Leo
  20. #20
    Nov 2008
    Ql
    3,169
