The boat and hardware were traded for some assembly work on several other boats. Build includes:
MHZ 84cm Mystic in Carbon/Kevlar
MHZ high speed drives and rudder assembly
Lehner 1930 HiAmp LK motors with MBP couplers
MGM 28026 ESC's
Futaba Low Profile BLS551 steering servo
Batteries will Dinogy 4S 5Ah or Hyperion 4S 5Ah
I ordered the Lehners with the 6 output option so for SAW I can run Delta (as shown) and for play running I can wind in Wye.
The nose will be filled with foam and tips have epoxy+filler to give them a little extra strength in case of hit or more likely an accidental drop.
I am running 1/8" flex cables which should hold up fine although I was a little disappointed to see the right hand twist cable is stiffer than the left hand twist. Hopefully the extra stiffness will not cause too much drag.
I still need to scuff the bottom and add numbers and sponsors to make it a legal boat.
TG
