Like the title says...
What is the best value charger if I am only going to charge 2 4S batteries at the same time. Also no power supplies. I want one that plugs directly into wall outlet at home
Thanks for the input
DJI Drone Advanced Pilot
Canada
The Dura Trax only charges up to 3s, heads up.
You need to have a price threshold:
option #1, you can buy two chargers at a lower price per unit but they will only be powered by external DC power source.
Option #2,if you want to get a duo charger with AD/DC feature, and be able to charge up to 4s lipo, you could possibly pay more than option #1.
Thanks for the info. That HiTec piece would work great. Not bad price at all...
rhgraphix.
That Hitec charger is only rated to 50W per channel. Although it's probably a good charger, it will not charge a 5000mah pack even at 1C. About 3.5 Amps is all it will charge at for that size pack.
If you are wanting to charge 2 packs together to save time, (I assume you are) then this one might be better. Basically the same charger under a different name, but rated to 80W per channel, and will charge at 7 amps. Slightly better than 1C. Cheaper too.
http://www.ebay.com.au/itm/AC-DC-QUA...32b9d76&_uhb=1
I have no experience with either charger so I can't say whether they are good or bad.
All the best.
Paul.
Thanks for the info. This is why I asked. I knew someone would know much more of the technical side.
