Results 1 to 8 of 8
Thread: UL-1 programming issue
    May 2013
    10
    Default UL-1 programming issue
    Just picked this up last night and after waiting all day to get in the water I can't program the esc. I followed the instructions. With the transmitter on I plug in both batteries and all I get is beeping that never stops until I pull the trigger. Then it'll beep once. I then release it and nothing till I hit reverse, which I'm not supposed to. Once I release reverse to neutral I get the three beeps. So neutral is trigger pulled and forward is neutral position. Tried everything I know like switching motor wires and rev on the transmitter. Please help the sun is going down!!
    Jun 2012
    MA
    1,876
    Make sure throttle channel is reversed and trim all the way up, then try
    Jul 2010
    Tx
    175
    May also have to hit the little tiny bind button on the receiver with a tiny screwdriver!
    May 2013
    10
    I tried trimming forward and it kept beeping. Went the other way and stopped on the backwards trim at 32%. Kinda odd.... But it was able to program that way.
    Thanes--- thanks man but I'm using my 4pks.
    Jun 2012
    MA
    1,876
    Oh, had you mentioned that I wouldn't have made my suggestion. Of course it didn't work, you aren't using the tactic remote.
    Glad you got it going
    May 2013
    10
    Yeah but if you hadn't mention trimming I'd still be in the garage banging my head against the wall. LOL
    Jun 2012
    MA
    1,876
    Haha well glad I could help -D
    May 2013
    10
    Thanks Heaving Earth!
