Hi I have a impulse v2
Upgraded shaft(ose)
Sharpened and balanced m445 prop
Dual rudder kit(esc has its own water pick up and outlet as does motor)
I run two 3cell 6000mah batts(never gets above warm)
I want to upgrade my motor to the leopard 4074 2000kv vs stock 1800kv(which is just a little longer than stock)
My question is
will it fit the stock motor mount(both are 540 cans)
And how much of a power/speed difference will I see
And my esc should handle the amperage drawn if I'm correct?
Thank you for reading and any advice would be helpful even if its not about my question.
