What about a spreadsheet to help users decide on a build?
"Updated" with Lipo and esc amp ratings. There are too many variables for this to be exact for all of the different hull and motor loads. Many setups will fall outside of this general data spreadsheet. Just hope this gives you a better understanding of FE for designing successful setups.
--hull size /--------Cells---------/ ----Motor Kv----- / -------Prop Size------/---Type ESC---/-BEC-/ESC Amp Rating
17”- 24” / 2s LiPo or 6 cell NiMh / 5500 -3200Kv / 30mm - 40mm Diam. / Low Voltage / Avail. / 120 amp
20"-27" / 3s LiPo or 8 cell NiMh / 3500-2500kv / 35mm – 42mm Diam. / Low Voltage / Avail. / 120 amp
24”-29” / 4s LiPo or 12 cell NiMh /2650-1600Kv /37mm - 46mm Diam. / Low Voltage / Avail~Disc / 120-240 amp
26”-32" / 6s LiPo or 18 cell NiMh /1800-1100Kv /40mm - 52mm Diam. / Low or High / Disc. / 120-180-240 amp
30"- 36" / 8s LiPo or 24 cell NiMh / 1350-800Kv /45mm – 55mm Diam. / High Voltage / N/A / 180-240 amp
34" - 42" / 10s LiPo or 30 cell NiMh / 1100-600Kv /47mm + Diameter / High Voltage / N/A / 180-240 amp
38" - 46" / 12s LiPo or 36 cell NiMh / 900-550Kv / 50mm + Diameter / High Voltage / N/A / 240 amp
Always start testing with a small prop and work up to your desired amp readings!
HULL SIZE AND OSE MOTORS
This is a general guideline for the motors OSE sells. I know it is hard for this to cover all selections, since FE setups can be complex and extend over a wide range of extremes. Remember this is more for conservative setups to help new guys get started.
hull size…..... /…...... Neu….... /….. Feigao.540…../Feigao 580/...700SC../.SV27./.Proboat./..Ammo../.380.
<<"-20"....../.....1506........../.......Fiegao.S......./................./................./......../............../.............../.380 L
17”-24”…../….. 1506,1509./…..Feigao S-L…...../…............../................./......../............../................/........
20"-27"…../….. 1509,1512./…..Feigao L-XL...../….............../...700SC../.SV27./.Proboat./..Ammo../........
24”-29”…../…..1512,1515../…..Feigao XL…...../….............../...700SC../.SV27./.Proboat./..Ammo../.......
26”-32"…../.....1512,1515../…..Feigao XL….../….............../.,..700SC../.SV27./.ProBoat./............./........
30"-36"…../….. 1515,1521./…........…………..../….. 580L...../.............../........../.............../............./........
34"-42"…../….. 1521,1527. /…........………..…/….. 580L...../................/........./................/............./........
38"-46"…../…..1527,2215. /….. ......……..……/................../................./........./................/............./........
40"-60"..../.......2230......./Little Screamer 63mm outrunner/
MOTOR MAXIMUM WATT RATINGS.
Always look at the maximum WATTS the motor is rated to handle. The heat will kill the magnets and possibly the controller if you get it to HOT.
Continuous rating/ 30 second rating
Neu -
1506 - 700 watts/ 1500 watts
1509 - 1000 watts/ 2000 watts
1512 - 1200 watts/ 2500 watts
1515 - 1500 watts/ 2700 watts
1521 - 1700 watts/ 3000 watts
1527 - 2100 watts/ 3300 watts
2215 - 3000 watts/ 5000 watts
2230 - 6000 watts/ 10000 watts
Feigao
580L - 1800 watts/
540 XL - 800 watts/ 1600 watts
540L - 600 watts/ 1300 watts
540S - 450 watts/ 1000 watts
380L - 450 watts/ 1000 watts
SV - BlackJack 800 watts/ 1400 watts
Ammo 2300 - 700 watts/ 1400 watts
700sc - 650 watts
Volts (X) Amps = Watts
Always calculate your setup Watts and prop it to run close to your motors Max Amp rating. (maximum effeciency rating)
Example:
Specs for the motor in the BJ
TURNIGY brushless Inrunner
Power: 460W
Battery Config: 3-5S
Watts / Volts = maximum AMPS to keep motor cool - recommended by manufacturer.
460 watts / 11.1volts = 41.4 amps max
460 watts / 14.8 volts = 31 amps max
460 watts / 18.5 volts = 25 amps max
FeCalc can get you in the ballpark for loaded 2-pole motor watts and amps. It is just an estimate, but can give you a good idea of which prop to start testing with.
