Results 61 to 90 of 96
Thread: Miss Geico dialed in- strut modification
  1. #61
    Mar 2013
    43
    Hi,
    My son has been racing his Miss Geico (V2) in the p-limited offshore class, and we have it dialed in on stock setup with x642 prop. Batteries are just behind the front end of the motor (non-shaft side). Per the tips on the forum, I ground a wider slot in the strut, allowing a bit of negative angle. I have the strut up pretty high-- with the sponsons on the table the shaft does not touch the table-- close-- probably less than 1/8 above it (in the picture it looks like more, but that is just due to the camera angle).
    In race conditions (ie, some race-induced chop in the water), the boat rides perfect, no bounce. In glass water, we get a slow bounce. I have not blueprinted the sponsons, and probably won't bother as the boat is doing great in race conditions.
    Been too busy coaching my son through the races to get a video, but will try to get one next time.
    Chief
    How do you plan to "blueprint" the sponsons?
    Is there a dimensional drawing available?
  2. #62
    Apr 2011
    5,666
    Quote Originally Posted by Arizonaheat View Post
    So-called "blue printing" the sponsons is just a process to make the bottoms match each other and to make sure that they are flat when placed on a flat surface such as a glass table or granite top counter. See this thread:https://forums.offshoreelectrics.com/...ace-Prep/page2, specifically read from post #43.
  3. #63
    Jan 2013
    BI
    38
    Quote Originally Posted by Shane_744 View Post
    Longest time was bending the stuffing tube correctly and keeping the strut lined up while tightening it.
    Do you taking the stuffing out or does you only bend it with hand strenght? heating?
    Mine is hard as a stick (stuffing :-) )
  4. #64
    Apr 2011
    5,666
    Quote Originally Posted by jsturess View Post
    If you don't plan to replace the stuffing tube, you need to bend it with your hand strength, heating it on the boat will soften the FG exit point and also the epoxy, that is how people take the factory tube out BTW.
    You need to take care not to kink the tube. The only portion you need to bend is where it goes into the strut, basically make it straight so you can point the prop down a bit. The suggestion is to insert the largest drill bit possible to the open end of the tube and gently shape ( bend) it.
  5. #65
    Apr 2013
    Ma
    288
    @ Alan
    What speeds are you hitting on the gps with your setup? Also curious what kv that motor is?
  6. #66
    Jun 2013
    fl
    9
    Just wanted to say thanks to op for the mod. It has helped my bj29 a lot with the traxxas system in it
  7. #67
    Feb 2013
    54
    @ speed racer - it's a leopard 4082/1600. Haven't GPS'd it yet. Took it out yesterday and got pretty much the same performance out of it.
  8. #68
    1,969
    Well my son ran his boat up on some rocks and ripped up the sponson, so that gave me an excuse to blueprint it! I used West Marine Epoxy Putty. Super strong and sands easily. I'll try to take it out on a test run next weekend before I repaint it.
    Chief
  9. #69
    1,969
    Did a test run with the Miss G's repaired and blueprinted sponsons-- wow, what a difference!! The bounce is even further reduced, but the real benefit is that the sharp edges on the back of the rear sponsons keeps the nose down much further than stock (the sponsons are pretty rounded out of the box). I did not change the strut position at all, and the nose is way down. On this run I pulled the batteries back about 1" (which would have caused blowovers previously). I think I can even reduce the negative angle I have on the current strut position a bit.
    I think the only thing left causing any bounce at all on glassy water (with this config it is not a problem-- any racing induced chop lets the boat run great) is the rooster tail hitting the center mounted rudder. The next experiment will be to use an offset rudder. For sports running the center mounted rudder works great as it has equal left/right turning, but my son is racing this one in offshore class so offset should work just fine.
    I've been doing free s/b of the stock props and also free strut mods on the RTRs I sell at my webiste (see sig), I think I'll add blueprinting as an option since this turned out so well. The marine epoxy putty is a bit expensive but is the perfect consistency and is super strong.
    Here's a video of the run:
    Chief
  10. #70
    Sep 2010
    nj
    4,289
    Hey.
    Look like it came out pretty good,
    Is mike legally blind ?
    Look, It's a moving green bullseye.
    I just started testing the setting on mine today,
    And got some pretty good video to I think.
    I will see what it looks like and than may be post it if it looks ok.
    ? ONLY IF THEY WORK
  11. #71
    Mar 2013
    ny
    66
    hey cheif where did you buy the marine filler? i have my old bj hull awaiting carbon fiber/kevlar inlay and some sponson blueprinting after the seam split
  12. #72
    Feb 2013
    54
    Chief, she runs pretty flat and smooth. Can you share some close up photos of the edges you're referring to?
  13. #73
    9,402
    I like that stuff. I wonder if I can get it in Canada??
    Chief
  14. #74
    Mar 2013
    ny
    367
    i wonder if it would make a difference when you would make the last step 90° angle ?
    now it's about 100-110°
    the MG v2 iss my first cat ,so i'm not an expert on this matter but in the mono-world we make the point where the water has to "leave" the bottom of the boat razorsharp and 90°
    when i was blueprinting mine i was thinking about doing that , but did not
    mine has still a very small bounce on flat water
  15. #75
    Mar 2013
    104
    Same thing with full-scale performance boats. A sharp, 90° square trailing edge is ideal. The water comes off clean with less drag.
    '89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
    ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XP
  16. #76
    1,969
    Quote Originally Posted by AlanD View Post
    Here are a few more pics. I found the putty at a marine supply store that sells West Systems products.
    Chief
  17. #77
    Nov 2010
    ca
    254
    the biggest thing to do with this hull to stop the bounce is blue printing the hull, I have tried everything in the past and the biggest change was when I blueprinted the hull made all the edges to 90 deg and razor sharp, I also used a rudder offset and angle the rudder forward this helps with the bow ride height, I also use 2x4s in p, I personally cannot see the advantage of having any extra cells infront of the motor its dead weight and just slows your boat down and I am sure its this extra weight that is helping pyro's boat run flat, but how much speed is he losing carrying the extra cells. My MG runs great tlaunder has seen it running and i'm sure he will back me up on this, I run my MG in prod class with a aquqcraft 2030kv motor and the same 2x4s in p on a x442, and when i'm just messing about I put a castle 1515 1y in it with a m445 and it flies, if you can get this boat to around 50mph it just flattens out and flies. There is a video on here somewhere take the time and look for it and you will see what I mean
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
  18. #78
    Mar 2013
    104
    Looks can be deceiving. I'm using the same overall COG as many others who are running a pair of 3s packs. I have blown over three times using this COG. It's NOT bow-heavy. I have tried it more forward, and it tends to plow the front end at lower speeds.
    The strut mod helps lift the stern, so the tunnel is not constantly trapping and "burping" air pockets out the back, which is the hallmark of catamaran porpoise in the 1:1 world.
  19. #79
    Nov 2010
    ca
    254
    Pyro I am NOT saying the mod doesn't work, what I am saying is the weight of the extra battery has to be slowing your boat, I have done that mod myself you have to to move the strut up as far as you need to and have +/- angle adjustment on the MG v1. The other thing is every hull is different, your setup might not suite my hull and vice versa, there is loads to take into consideration when setting up a boat. For me IMO carrying that much extra weight does not make sense, there again when I'm racing I want to run as light as possible
  20. #80
    Apr 2011
    5,666
    Quote Originally Posted by CHIEFY_44 View Post
    The first time after my blue printing the ride pad, i thought to myself, big deal, now let's see if it really makes a difference. I was speechless the moment I pulled the trigger. I have also found that dead weight infront of the motor is useless, I put a heavy 5000mAh nicad stick, the boat still bounced.
    My mistake is not doing a 90* on the back of the ride pad, after seeing how great yours was running, i will go back and redo them the future.
  21. #81
    1,969
    Hi Chiefy_44
    Where in CA are you located? I'm in San Jose,
    (the other ) Chief
  22. #82
    Nov 2010
    ca
    254
    Hi chief I live in Rancho Dominguez just off the 91 fwy
  23. #83
    Mar 2013
    104
    Pyro I am NOT saying the mod doesn't work, what I am saying is the weight of the extra battery has to be slowing your boat...
    If it's slowing it down, then why am I running close to 60 mph on a stock motor and ESC? The third pack is NOT for dead weight, it's a third 2s pack wired in series for 6s total. It does not run bow-heavy this way-- I have seen three blow-overs with this center of gravity, but rarely any bouncing.
    When I run 4s (two packs), I put the side packs slightly more forward and it still runs nicely, with a high-flying bow, and no bounce.
    6s:
    4s:
    If anybody is wondering... I made the pair of spacers in the photo from thick commercial rubber roof sheeting. Each one is a rectangle of flat rubber with the motor wires threaded through three tight holes. This keeps the stock motor bullets cooler, and keeps them from making contact with anything if the heat shrink gets hot enough to soften. Works great.
  24. #84
    1,969
    Here's another video from a run we did yesterday-- since blueprinting brought the nose down I was able to set the strut completely neutral, no negative angle. The bottom of the propshaft is even with the sponsons (just put the boat on a flat table, and set the strut so everything was level). So bottom line-- if you blueprint with 90 angle off the sponson, you could skip the strut mod altogether.
    Chief
  25. #85
    Mar 2013
    ny
    367
    runs great!
    hope to achieve the same !
  26. #86
    Jul 2010
    14
    412
    Yeah that was super to watch, great Place to run to. Love those Places were you get a bitt above water Level.
    Drammen rock City
  27. #87
    Jul 2007
    MD
    198
    Very informative thread. Subscribed.
    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
    '09 Miata.
    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
  28. #88
    1,969
    Quote Originally Posted by hydro_pyro View Post
    I'm pretty sure that's all high-quality aluminum, but I could be wrong. Aluminum tends to wrap itself around the Dremel bit, clog up the abrasive surface, and sort of "burn" away while you're grinding... This can make it more difficult than some other materials.
    I used a spiral-fluted metal cutter bit, and finished with a small stone bit.
    Hi,
    I made this mod for a few customers and this time used a rattail file to widen the strut slot-- much easier than the dremel.
    Chief
    Sent from my XT890 using Tapatalk 2
  29. #89
    Apr 2013
    Ma
    288
    I can't see a link to video. But that is impressive to have am MG near 60 with stock motor.
  30. #90
    1,969
    I have a Word doc that has both Miss Geico and Blackjack mods and setup I have made documented, and also has a great overview on prop selection. I have not yet updated it with the blueprinting process, but I will get around to it this winter.
    If anyone would like a copy of it, please email me at jqhydro@gmail.com
    Chief
