I have a grimracer 42x55
when i started balancing it was obvious that one blade was heavier then the other,but now it always stops horizontaly when i spin the prop
it's always the same side thats underneat
so the hub is heavier on one side?
and if so ,what to do ?
there's also a lot of movement possible when i put this prop on the axle (nut not tightend) or the balancing shaft
the stock prop ( impulse 31) fits without any possible movement like you would expect
