Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: Feedback on Hor Racing Zonda 41
    Apr 2013
    UK
    27
    Default Feedback on Hor Racing Zonda 41
    I'm thinking of getting the above cat and run 8s, I've searched the forum and found very little info of them, so if anyone has one could they post any finding, info, hints on this post please
    AJ
    Proboat BLACKJACK 29
    Jul 2010
    NS
    577
    Ive heard someone broke off the transome on the carbon one
    Id just get the fibreglass one and re enforce it.
    its cheap, can run single or dual setups
    Apr 2013
    QL
    241
    I have a zonda and run it as a twin on 5s each side. Got tp 40mm 2000kv and swordfish 200 amp speedy fiberglass
    Apr 2013
    UK
    27
    I love the look of the carbon ones, is it worth the extra money for the Kevlar version?
    Apr 2013
    QL
    241
    I liked it to but cost stopped me buying on. Andrew said a transom broke off on carbon one I would look into that.
    Apr 2013
    UK
    27
    I'll try and dig up some more info, my thinking was that the Kevlar version should be stronger than the full carbon version??
    Jan 2013
    SC
    53
    I have the zonda carbon with twin 4074 2000kv and turnigy 180A esc on 5S.
    It works great but the hull is very thin. It got only one layer of thin cf so you can se through the hull.
    But the transom is re enforced and I layed a layer og cf over the motormounts and as far ahead as I could get to.
    I think it will be tight to fit twin 8S but single should be fine.
    My 5S packs do not fit in the midle of the hull, barely fits 4S.
    I have run it with 450/3 props and it is FAST. I have no GPS run on it but i would guess way over 100km/h and the speed calc. here says 106.
    Apr 2013
    QL
    241
    I used SF 200 and can fit 2 turnigy nano tech 5s 5000mah
    Dec 2011
    1,447
    Really fast boat with even a small setup. You'll love it. I would get the fiberglass one and bulk it up. I own 3 tfl/horracing hulls (fc super daytona, standard daytona, and cheetah) they're nice hulls if you don't have plans to go really fast. They're very thin in some areas but reinforcing is part of the fun. The super daytona is great though its comparable to my mystic 138.
    Apr 2013
    UK
    27
    Where can I get a fibre glass 41?
    Aug 2012
    fl
    146
    Quote Originally Posted by <AJ> View Post
    Im building one right now its called the fantasm and keithbradley or fightercat sells them with a carbon fiber and Kevlar inlay for less than $200. If you think $650 is a lot for a zonda cat it's not if you start pricing out parts. 2 cheap 4074 motors $200, two t180s $200, hull $200, batteries to run 6s $300 + $250-$400 for hardware servo, stingers etc. What im saying is its not a cheap boat to build from scratch and ill have over $1500 in mine after paint. And if you buy lets say castle escs and motors add another $500
    Apr 2013
    QL
    241
    Where abouts you live AJ?
    Apr 2013
    UK
    27
    In the UK, i think I'm going to order the Carbon version direct from Hor Racing
    http://www.horracing.com/product_inf...roducts_id=566
    I've got some Nano 4500 45c 4s lipo's from my brushless 1/8th buggy I can use and ill get a pair of Seaking 120a esc
    May 2008
    Oz
    2,981
    Jamie@OSE
    CF Zonda
    2x Sirius 1518/1800
    2x6S
    2x SF240
    78.5mph ..
    edit: link removed because facebook wouldnt share !
    LMK if this doesnt work when you hit the link above
    Apr 2013
    UK
    27
    Link doesn't work for me, but might be my stupid iPad tho xD
    May 2008
    Oz
    2,981
    cameras gaffa taped to caps dont really do justice to this hull's performance !
    Jan 2013
    La
    295
    I just bought a df pirate 35. Spent 25 bucks on carbon fiber kit on ebay. It took 30 mins to line the hull and came out great.
    Oct 2011
    OZ
    314
    Got the CF Zonda. Yes the hull is very thin and it's a bit disconcerting being able to see a whole lot of daylight through it. My hull leaked like a sieve when I first got it and I had to seal over all the through-hull bolts and screws. Trouble is - it is extremely difficult to reach the rear of the boat from inside with any tools etc etc. Ended up having to pipe some glue in and just let it set over the mounts for the stinger angle adjusters. Running the black can 2075kv motors that come with the hull in the ARTR version. Run 2 x 5S Thunder power 5000mah batts, but I had to cut spaces for them from the internal mounting tray. Once you do that though the 5000mah's fit without issue.
    Honestly I'd get the hull only and put decent motors inside. So far I have topped out at 90km/h - and that was with slightly oversized props that had me heating things up real fast.
    Will not turn at speed with the stock rudder. Looking to fit a larger dual pickup to mine.
    Anyone can give me a way of setting this boat up to go faster and I'm listening.
    Good hull though. Definitely will handle more speed than I've been able to get into it.
    Was thinking of going something like 1800's on 6S like drwayne reports above.
    PERTH AUSTRALIA
    Apr 2013
    UK
    27
    Thanks, that's the best reply yet, I'm still haven't been put off getting one. Its going to be an ongoing project that won't be rushed, so even the small pit falls are not anything I can't work through :)
    Apr 2013
    QL
    241
    Iron go to rcboatbitz.com they have upgraded zonda rudder with dual pick up and the rudder itself is wider which I finds helps in the turns. Blacks can do you mean TP motors? Mine has TP 4082 2180kv with 43x1.6 props and runs 96 with temps below 40. Have you adjusted the stinger angles up a couple degrees and which way do your props turn in or out?
    Jan 2013
    La
    295
    Try this on your hull. Worth about 8 percent gain speed.
    http://youtu.be/IPM8OR6W6WE
    Oct 2011
    OZ
    314
    Wow! That Ultra Ever Dry stuff looks truly amazing! Might see if I can't source some of that stuff somehow. Thanks for the tip Bduncan!
    Ahh hah! Thanks for the pointer about the upgrade Zonda Rudder Mulisha! Been looking for a rudder I could mod onto the Zonda for some time so this is even better! Checked Boat Bitz a while back for Zonda Upgrades but didn't come up trumps that time. So this is just what I need. Ordered one straight up.
    So far as I know the black can 2075kv motors are the TP ones yes. I think someone on this forum sleuthed that one out. On 4S I'm currently running some 48x1.4 props which makes the boat go around the 70km/h mark. On 5S I run 45x1.4 props which pushes me up to about 80km/h. However, Just discovered that my throttle trim might be glitching so I need to get that sorted before I can be confident that those figures are the best I can do on those setups. Would explain a few things actually.
    If I go the 48mm props on 5S, I get into the 90's but just did that once as a test. Motors begun getting hot as you'd expect, so I couldn't do a full run.
    I have got the stingers adjusted up a little yes, which did help. Also have the one piece drive cables from Kintec, which are an absolute must in my opinion. Mucking with the two-piece stinger drives after each run is pure madness!
    AJ
    No don't be put off at all. These hulls are decent, just do some research and don't pay too much. All issues have a solution :). No build issues with my CF hull after quite a few runs & one nasty stack where I got the boat airborne. With decent hatch tape, no water got inside at all.
    PERTH AUSTRALIA
    Apr 2013
    UK
    27
    I'm now sold, I will be ordering a Zonda from Hor Racing next week :)
    Apr 2013
    QL
    241
    Let me know what speeds and set up you decide. i got twin 4082 2180 TP motors 5s and 43x1.6 props and thinking of going up a prop size
    Apr 2013
    UK
    27
    Will do, the plan at the mo is to get the rtr version with the 2075kv motors, team up with a pair of Seaking 120 esc's, with a pair of nanotech 4500mah 45-90c 4s lipo's. Then sometime in the future go for 40mm can motors and 5s.
    I'm sure a stock motor will make a good upgrade for my BJ29, so the stock motors won't be a wasted
    Apr 2013
    UK
    27
    Also I will be getting the dual pick up rudder from Rcboatbitz and sorting a proper servo mount
    Apr 2013
    QL
    241
    Love the BJ29 wish I waited for it to come out instead of getting a spartan. I think a few other places sell the rudder upgrade. I have had a bad time with boatbitz lately sending out "upgrades"that don't fit there own gear.... Bought 3/16 flex with threaded end and 3/16 prop nuts threads are different...
    Apr 2013
    QL
    241
    Just had to trim the tray to get the servo in on mine, cut out a section for the batteries otherwise they sat to high
    Apr 2013
    UK
    27
    Nice, looks a sweet setup :)
    Oct 2011
    OZ
    314
    RC Boat Bitz is currently out of the Zonda Rudders. My order for one just got knocked back. 2 weeks apparently. They *must* be a part elsewhere surely.
    Anyone know where else I could try??
    http://shop.rcboatbitz.com.au/index....oducts_id=1084
    Edit: I see there is a note on the RCBB site saying the rudders are manufactured by them. Just gotta wait it seems.
    PERTH AUSTRALIA
