Page 1 of 6 123 ... LastLast
Results 1 to 30 of 157
Thread: atomic 58 inch catamaran motor question
    Jul 2011
    141
    Default atomic 58 inch catamaran motor question
    hi, can I put a leopard 5692 1000kv inrunner with jacket in this cat?
    Jul 2011
    141
    anyone??
    Sep 2010
    nj
    4,289
    Hi.
    It runs pretty good with the V700 1100kv Marine Outrunner and a sk 120a esc on 6s,
    So it should work great with that motor or a lower kv one.
    You may want to beef up the hull some because of the added torque of that motor,
    And added weight of the cells to.
    What cell where you thinking of running in it ?
    ? ONLY IF THEY WORK
    Jul 2011
    141
    hi, will the stalk motor mount fit a leopard 5682 in there? or will I have to get another motor mount?
    Jul 2011
    141
    down the road will it go good on 8-10s?
    Jul 2011
    141
    I was thinking of an inrunner because I like to have a water jacket. does not look like good cooling on a outrunner? would a tacon bigfoot 60 be ok?
    Sep 2010
    nj
    4,289
    On the motor mount,
    I think you will need something better.
    Plus the bolt spacing is wider I think,
    And the ID of the motor can is a lot bigger to.
    Hear a link to some pictures of a members on hear.
    https://forums.offshoreelectrics.com/...Atomik-58-pics
    I am not sure if he up graded his yet.
    He also just did a kos 56" mono to FE but has not got it wet yet.
    ? ONLY IF THEY WORK
    Jul 2011
    141
    hi, I think you wont even fit a 56mm motor mount in the arc because of the wider rails on these 56mm motor mounts?? wont fit across, will hit the ply woood?
    Sep 2010
    nj
    4,289
    No,
    You may just need a custom mount made.
    If the rails are a odd ball size,
    No real big deal to have one made to order on hear if need be.
    Do you know what the rails ID is ?
    ? ONLY IF THEY WORK
    Jul 2011
    141
    no I dont. I tried to ask the fellow that you sent me the pics that has the boat but no reply.
    Jul 2011
    141
    lenny, can you find out from the guy who has the arc, the id between the ply rails?
    Jul 2011
    141
    Lenny, I found from atomik for id of rails, the guy said" I went out and measured that for you and I came up with 75.85mm" should I be able to fit a offshore 56mm $18 motor mount in there, if mount is only 67mm across?
    Dec 2011
    1,447
    Can't comment on the motor mount but 1000kv is high. I would run something to the tune of 700-750kv on 12s. The boat will really move and you'll have decent temps.
    2,686
    Get a williams racing 3 inch rail mount. it doesnt have the sides like the stock mount.
    Apr 2011
    AB
    I too am looking for a motor/esc combo for my new 58" cat (Atomik). Would really appreciate any help from anyone who knows which mount + motor would work in this hull. I like the idea of 10-12s on a 700-750kv. Not racing or anything - just looking for a reliable recreational setup. Thanks in advance!
    Oct 2008
    9,488
    for you guys looking to put big motor in this hull
    http://www.offshoreelectrics.com/pro...prod=ose-80076
    a simple 750ish kv on 8s with a gas size prop would make for a really good runner!
    there is a guy on youtube who converted the gas version and used a 540kv on 10s with the stock gas prop and that sucker moved
    way faster than the stock gas motor ever could
    Jun 2011
    PA
    51
    Hello, just got my ARC 58, is amazing.
    Any tips for me? I just put some positive angle to the strut and cavitates alot.
    38mph with the GPS
    Chris
    May 2013
    NJ
    294
    I installed a Leopard 5692 - 1090KV last night with a water jacket. I used the existing side mounts from the motor mount. I bought a piece of aluminum from Lowes to make a new front plat for the motor to attach to. I will post pictures later. I had to buy a new coupler and replace the hose for the water to exit from the motor. The line in was the right size in length. Will run it on two 4S packs.
    I also have a New Leopard 5692 - 730KV for sale.
    Jun 2011
    PA
    51
    Please send the pictures, sound very good what ESC are you planning to use?
    What is the difference of using the same kv motor but with longer ones 5674, 5692, 5698 or 56110?
    Here is my vid with the stock ARC http://www.youtube.com/watch?v=ffcq3VfA3nQ
    May 2013
    NJ
    294
    The one line is not connected for the water discharge. The original bolts that secured the side brackets cannot be used because they will prevent the motor to fit with the water jacket. Using the original side brackets will allow you to adjust the pitch. I had to make a front plate. It was not hard, took my time to make sure the holes were in the correct location. I bought new screws to secure the motor to the plate. Then solder the new bullets onto the ESC. On the second try I had the motor wires correct for rotation. Hopefully I will be at the lake on Thursday to find out how everything will work.
    Sep 2010
    nj
    4,289
    What make is that 200a esc ?
    That motor will pull some high amps from it on 8s,
    Also what prop will you be starting with ?
    ? ONLY IF THEY WORK
    May 2013
    NJ
    294
    The ESC is a no name. I have been using them for awhile without any problems. I think the current ESC will be enough for this setup. Hope to find out on Thursday.
    I will try the stock prop and a prop that is the next size up that I am currently using. I will be watching the temps and be using the GPS to know if the props are working.
    Jun 2011
    PA
    51
    Waiting to hear how the setup works
    May 2013
    NJ
    294
    I am waiting to go. LOL Today was the day to go, I had to decorate the house for Christmas. Spoke to my friend about a date to go run. Looks Like December 1. He is off on Sundays and Thursdays. I am excited to see this thing run. Curious to know what MPH. Between myself, Damen and Ken we all have different predictions. Ken is thinking maybe 70mph. Damen said 60mph and I think I will see 65mph.
    Sep 2010
    nj
    4,289
    Hi,
    You should post some video's of your in the video's pictures threads.
    The difference is the motors can sizes and lengths will give more torque and should be more efficient,
    Than the stock motor in that size of a hull.
    So it should run better and faster and cooler to in the long run,
    But only If the boat is setup right and running free and airs out good.
    And if it is not setup right it well not be efficient,
    It well run hot with low speeds and will have short run times to because of it.
    Quote Originally Posted by cgd2175 View Post
    ? ONLY IF THEY WORK
    May 2013
    NJ
    294
    I also have 4s for the new setup. I will do the same balance test as I did with the old setup. The way I did the setup on the old setup worked out very well, everything was very cool after a 4/5 minute run.
    Sep 2010
    nj
    4,289
    You will be running that 5692 1090kv motor on 4s ?
    What is that no name esc rated at 4s, 6s, 8s, 12s. ?
    ? ONLY IF THEY WORK
    May 2013
    NJ
    294
    I will be running two 4s to equal 8s total.
    I will need to check on the ESC rating.
    Sep 2010
    nj
    4,289
    If I where you,
    I would not be worried about the speeds at this time.
    But I would be worried about that 200a no name esc going up in smoke and everything else in the hull to,
    especially If you push that setup and it is not trimmed out right yet.
    Is this the no name esc you have in the boat now and you plan on running it on 8s ?
    It is rated at 6s tops.
    http://search.yahoo.com/r/_ylt=A0oG7...ler-SL184.html
    And the same one hear.
    http://search.yahoo.com/r/_ylt=A0oG7...-with-bec.html
    ? ONLY IF THEY WORK
    Sep 2010
    nj
    4,289
    Quote Originally Posted by Finest Racing View Post
    Yep I think that would be really really good idea to do,
    JFC before you three stooges blow your self's up.
    ? ONLY IF THEY WORK
