Originally Posted by
kendt
Good timing. I am just finishing up a ts3 build for 6s. (even though I was told it couldnt be done he he). I did a fair amount of work to re enforce the transom so I could use a 7.5 lower unit. For now I will go with the bullet drive. Only because I need to do some cutting on my k&b lower to get some weight off. I will start with the bullet dr and see how it goes. For motors I have a scorpion 3226 1600kv. It should be a good match for this size hull. I also have a 3659 edf motor. It is a 1900kv motor though and likely too much for this hull but once I have my hull set up and running well, I will likely try it. as for props i will be keeping it small until i have logged some good data. I couldnt afford a sf 200 for this build so i had to go with a 120. I have a couple of t180.s but there was just no practical way to get it in the bull.Hopefully be testing in another week.
Where there's a will (and four 90deg. fittings + some patience) there's a way to make T-180's fit narrow confines
