Results 1 to 14 of 14
Thread: Rudder servo?
    Jun 2012
    Ny
    348
    Default Rudder servo?
    I recently built a fantasm with a scale rudder. It seems to me that my servo may not be strong enough to do the push and pull with the cables. I'm using a hitech servo not sure what number. But it seems to me that it's slow. If I turn left or right it stays like that I need to move it back it doesn't go back by itself What servo should I get. I'm not looking to go crazy and spend a lot on a servo. I have more hobbie's to support lol. Can I get some ideas on what to get.
    Jun 2012
    Ny
    348
    Default Pics
    Pics of servo
    Jun 2012
    MA
    1,876
    Shorten the servo horn so your cable are closer to the servo, it will have greater force closer to the center. Also look for binding in your rudder
    Jun 2012
    Ny
    348
    Deff will do that. But I'm thinking of getting this. http://www.amainhobbies.com/product_...tal-Gear-Servo
    Jun 2012
    MA
    1,876
    Good servo, but determine if the servo is the issue first
    Jun 2012
    Ny
    348
    I originally had short plastic 2 way horn on this servo and it was the same way it is with this horn maybe a little stronger. So I'm thinking buying a new servo and making the horn shorter.
    Aug 2009
    tx
    3,534
    There is a metal gear hi torque servo at ho for 10$
    Jun 2012
    Ny
    348
    Aug 2009
    tx
    3,534
    to rich for my blood , this is what i was talking about
    http://www.hobbyking.com/hobbyking/s...idproduct=9618
    Dec 2009
    on
    2,187
    You NEED to figure out where it's binding up. There is something defianately wrong in there if a 645 can't even bring it back to centre.
    Jun 2012
    MA
    1,876
    I agree. Although the op isn't telling us what he has tried. Is the rudder binding or is it a servo issue? Has he tested the servo itself? Has he tested the rudder itself by pulling the cables? I'm lost
    Jun 2012
    Ny
    348
    Quote Originally Posted by siberianhusky View Post
    If the servo is disconnected from the rudder. I can move the rudder with very little effort back and forth
    Jun 2012
    MA
    1,876
    Right, but that is holding the rudder and moving it? Have you tried moving the rudder via cable? Maybe the cables are binding?
    Jun 2012
    Ny
    348
    I did it with the cables as well. Seems good. There is a little friction but much. Also did it with holding the rudder and moving it while it's connected to the servo. And it moves good no issues. Only when I use the servo to move the rudder it seems slow and weak. I think it's the servo I ordered a new one. Like the one I posted. I'm not sure where my old servo came from. Even with out the cables connected to the servo arm it doesn't go back to center by itself. So I'm sure it's the servo.
