Lipos and your electronics should not be ruined by fresh water. I had my spec rigger under water for 6 months, everything still works (except servo) Motor speedo battery and receiver are still in working order. Wet lipos should have the shrik removed and placed in the sun to dry. Lipos should be taken care of but you don't have to be a LiPo Nazi, I raced batteries last week that I had fully charged in Oct,(they were still at 96-97%) and they ran the best they ever have. Dont worry about bringing you're batteries down to 5% or less I routinely do this on my offshore setups (as most people here know I love Offshore) just make sure you get some charge in them soon after you drain them (within a day or 2). Lipos stored with full charge will have a little higher resistance but once you run them and get a little heat in them they are fine. The most important part of running lipos is DON'T run them cold (60'F or less) this it bad because the IR is so high when they are cold heat builds up too quickly and then they have higher likelyhood of puffing. (this is even more prominent in older celkls and lower C rate cells) And I routinely charge my batteries 1-2 weeks before race day so don't worry about charging the night before. If I did that I would be charging from 8am to midnight, and I have over a dozen chargers. I have enuf batteries for each boat so I can run 3 heats and a practice run without recharging. So for example tomorrow I'm bringing 72 battery packs, could never charge in one day, much less even a week. If you have a few packs and you want to be vigilant and don't bring em down low or keep the strage charge at 50% this definitely cant hurt and will most likely be beneficial, but if you have a LOT of packs and just don't have the time to manage them "perfectly" they will be fine.
We call ourselves the "Q"
