Results 1 to 13 of 13
Thread: Revolt 30 motor/esc/prop/batt testing
    Apr 2012
    nv
    314
    Default Revolt 30 motor/esc/prop/batt testing
    So I got a little bored and decided to test some other motors in the Revolt and post my findings. This gives me more reasons to run rc boats everyday I guess. I plan on running several prop/esc/motor set ups with all findings. I was able to run today and use my Garmin gps trackometer. my revolt has the bulky stock battery tray and the left side turn fin removed and the right side fin is a sv-27 turn fin. The stuff tube was removed and re-installed and reinforced. The flex shaft now spins smoother than silk. The strut is raised 3/8 of an inch from neutral.
    So I decided to start with the 2300kv motor first. I have dual water cooling for my revolt as is needed for this kv motor.
    Motor: Great Planes Ammo 36-50-2300kv
    ESC: Hobbywing Seaking 120
    Batteries: Sky Lipo 2 2s 40c 3300mah
    Prop: Octura 440/3 Thinned, balanced & sharpened
    Timing: 11 degrees
    43.2 mph, 5 minute run time, Motor was not that hot, Batteries were were a bit hotter than I would like them to be. Esc was normal but the deans leads were hot.
    I honestly expected more speed from this set up first time out. This set up in my UL-1 produces 51mph. I was expecting at least 45mph. I plan to take my teperature probe next time out to get acurate temps. I will increase the timing to 15 degrees and raise the trim tabs slightly to get the boat to run a little more dry. I will try a few other props the next time out but I will not be using anything over 40mm with this motor as I do not want to melt it down.
    Feb 2012
    WA
    817
    Watching to see how this works out for you....
    Keep pushing it!
    Corey
    This is NOT a toy?!?
    May 2012
    940
    Nice work keep it fun.
    Mike
    Apr 2012
    nv
    314
    UPDATE: Ran the revolt today and had her running nice until she stopped. I had melted a motor wire out of its bullet connector. here are the results and the set up used.
    Motor: great planes ammo 36-50-2300kv
    Batteries: sky lipo 4s2p 3300mah 40c
    Prop: grim racer 42x55
    Timing: 18.75
    44.6mph
    run time less around 4 minutes
    now that I have to solder a motor lead I am going to run some tests with an aquacraft 2030kv motor on 4s and 5s and will post the results
    Jun 2012
    MA
    1,876
    You won't see any noticeable speed increase by changing timing, only efficiency changes. I think you should go back to 11 on timing.
    Apr 2012
    nv
    314
    Quote Originally Posted by Heaving Earth View Post
    I think you are right. I usually do not run the timing that high but wanted to try it with the motor and the larger prop to see what would happen. The only thing I did this last time out was melt down a connection and go for a swim (weather was nice).
    Aug 2012
    VA
    161
    I consistently get 48.7mph with the stock motor &esc and a x545
    CG3
    Apr 2012
    nv
    314
    Update:
    Motor : Aquacraft UL-1 2030kv
    ESC: Seaking 120A 11.5 timing
    Batteries : Sky Lipo 4s2p 3300mah 40c
    Prop: Octura 440/3
    run time 5:34 (got me a new timer)
    I made several passes and reset my gps each time and I averaged 43.2mph. I will have to prop her up a little bit more as all the electronics were cool. I did not bother to take any temp readings as the motor and esc were not even warm. Going to slap on a 42mm then a 45mm and while we are at it a 47mm. I know about the props that people have and their great speeds. I am aiming this thread towards the individual who got a hull and wants to build it up to run and may have parts laying around from another boat.
    Apr 2013
    777
    As a comparison, I'm getting consistent runs at 73.3 kmph (45.5 mph) with:
    Motor: Stock AQ 1800kv
    ESC: SeaKing 120A
    Battery: Thunder Power 4400mAh 4S
    Prop: Octura m545
    Overall Weight with Battery: 2328g
    I know my Revolt is heavier than most. Between the upgraded Hitec HS-5646WP servo, 2 part foam filling the bow, modified battery tray and an extra layer of fibreglass/resin in the accessible areas, I'm sure I've added 200g to the boat. I should have weighed it before the mods.
    Jun 2012
    MA
    1,876
    I run that motor on 5s
    Dec 2011
    95
    Quote Originally Posted by chipgibbs View Post
    CG3
    What batteries are you using chipgibbs?
    Sep 2013
    de
    54
    great thread dirtnsnowrider and i also run the aq 1800 on 5s so much fun lokking forward to the bigger prop
    Sep 2011
    nc
    40
    CG3
    Is the X545 just S&B or has it been modified?
    thanks Scott
