Results 1 to 17 of 17
Thread: Seaking 180 problem
    Nov 2012
    178
    Default Seaking 180 problem
    Programmed the ESC. Made a few runs - slower than expected. Temps at 90.
    Cannot get back in to check settings.
    Followed wiring sequence (ESC w/out built-in BEC.) and batteries are charged.
    Looking at flat lines on program card and motor moves when it beeps, when connecting power pack to ESC.
    Lost.?
    Sep 2010
    nj
    4,289
    Hey.
    Is the esc rx/program plug in the right way in the program box ?
    And is it in the slot at the far right of the program box ?
    Also you can just us a 2s pack to work with when trying to program the esc.
    Have any pictures you could post or a video to see what you are talking about ?
    Are you using the stock tactic tx & rx ?
    If so did you calibrate the tx to the esc first and also set the tx throttle trim switch to R , Before you tried programing the esc ?
    ? ONLY IF THEY WORK
    Jul 2012
    Tn
    1,202
    The slow run was probably caused by the lvc set to high turn it off when u get back in to program it and time your run start at 3 min and stop
    Sent from my FE Phone
    Im Only Responsible For What I Say Not For What You Understand
    Nov 2012
    178
    rx/progam plug in far right.
    Using different battery packs.
    Stock tactic tx & rx.
    Calibrated the tx to the esc first and also set the tx throttle trim switch to R , before trying programing the esc. Yes.
    But, I may not have used the "reset" button each time after "value".
    Still unable to get in, motor beeps and looking at horizontal lines on program card.
    Nov 2012
    178
    You are probably correct - Looked like half power. Will turn off lvc, when/if able to get back in.
    Sep 2010
    nj
    4,289
    Can you post some pictures of everything in the setup & tx/rx /card/ please ?
    And did you try a rebind to the tx to rx ?
    ? ONLY IF THEY WORK
    Nov 2012
    178
    Sorry, unable to download pictures at this time.
    Rebinded tx to rx. Motor runs, red light on ESC comes on under full power.
    Still looking at horizontal lines on program card.
    My Set-up:
    Castle 1415 2400kv
    Seaking 180
    (2) 4500mah 2s 50-100c
    All on 6.5 bullets
    42x55 prop (starting point)
    foamed
    Sep 2010
    nj
    4,289
    Is your esc rx plug,
    Plugged in to the program card slot on the right hand side of the card ?
    And the plug wires black, red, white, White wire of the plug on the right side of program card ?
    ? ONLY IF THEY WORK
    Nov 2012
    178
    All the way to the righthand side - yes, in that extra funny marking.
    White wire of the plug on the right side of program card - yes. (Red wire cut.) ?
    Sep 2010
    nj
    4,289
    No red wire cut,
    Are you using no bec ?
    With a separate rx batter pack in the setup ?
    ? ONLY IF THEY WORK
    Nov 2012
    178
    Yes, using a separate rx battery pack and following wiring sequence for ESC w/out built-in BEC.
    I read on OSE '...cut the red wire.'
    Not correct?
    Sep 2010
    nj
    4,289
    When doing separate rx just pull the red wire connector out of the plug,
    Than you can always put it back when you need it.
    Try to reconnect the red wire and just use the internal bec of the esc and try the program box again.
    ? ONLY IF THEY WORK
    Jan 2013
    BI
    38
    Which version of seaking?
    Nov 2012
    178
    180 with 4 extra cap banks, I think it's a V2.
    Nov 2012
    178
    It's a Seaking 180, a recent purchase from OSE.
    Nov 2012
    178
    Put the "Red" wire back and wham - There it is! I guess everyone knew that except...
    Just got back from the Lake - looks like it's getting close to my Goal of 60mph.
    Big Fun! Will GPS next.
    Just wanted to say "THANK YOU LENNY!"
    Still don't understand how the Sky gets brighter when the Boats running good.
    Sep 2010
    nj
    4,289
    Glade to help,
    But pictures would have made things easier for me and you.
    And look out for them blow overs chasing speeds and get some video's.
    ? ONLY IF THEY WORK
