Results 1 to 3 of 3
Thread: another question...antenna tube
    Jan 2013
    MA
    90
    Default another question...antenna tube
    Well, after a outting with my BJ 29 tonight it came back and the antenna tube was missing. Dont know how as it was glued on with elmers. Anyway...
    seeing I have to replace it anyway I am looking for a black antenna tube and was wondering if any of you know were I could acquire one? And what size
    (as in diameter). I have searched online and there are a few sizes to choose from. I need one to fit a a stock BJ 29 antenna. I know its a simple item but just want to be sure I get the right one. Thanks again for any help!
    -Fireman
    Jan 2011
    PA
    1,141
    If not here try kintecracing.com.
    Apr 2011
    5,666
    Quote Originally Posted by awfireman View Post
    -Fireman
    I use 1/2" silicone tube---the same water cooling tube in your boat to secure the antenna tube to the mount on the hull. slide a piece on the tube first and then carefully insert the whole assembly in to the mount.DSCN3275_3492.jpgDSCN3273_3491.jpg
    This not only makes a better seal against water but it will help to hold down the antenna tube more securely.
