Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: How Fast are you running?
  1. #31
    Sep 2011
    MN
    103
    Used a drill bit to set the strut height out of water distance.
    .188 to far out tried .125 out
    Got the boat to 44 mph
  2. #32
    Sep 2012
    ca
    103
    I am using Eagle Tree on mine. You can look at a graph chart in real time. Example: I have crashed my boat before and the chart shows I am cruising along at 72mph then it spikes up to 98mph and back to zero mph in about 1 second. Thus, top speed reads 98mph. I know I did not go 98 mph, so it was caused by the boat whipping around during the crash, like Grim said....I think.
  3. #33
    Nov 2012
    178
    Stock MC:
    43.2mph, x445prop.
    47.4mph, m645prop. Temps after less than 2 min run: ESC 152, Motor 130. Not good, but big fun.
  4. #34
    Dec 2013
    az
    1,228
    Been testing my mc with ul 1 motor..m445 prop..on smooth water timing at 3 degrees..hit max of 51.9..but really loose..no wind..In race trim..strut at around 2 degrees positive...right around 48..to keep from blowing over
  5. #35
    Sep 2011
    MN
    103
    Yes sit it gets real lose at 50 plus. I blew 1 over last fall and broke the hull.
  6. #36
    Nov 2008
    WI
    662
    I have run mine to 49 on the L45X68. I love the way this prop carries the boat!
    Grim
  7. #37
    Dec 2013
    az
    1,228
    Is that a grim prop? ?
  8. #38
    Sep 2012
    248
    Ran my MC today, hit 41 with GR 42x55 prop, using 4s turnigy 6000mah 45c bats
    than swapped batts and ran 38 using venom 3000mah 30c batts
    in the past with a crash, I saw 55mph on gps, which didn't really occur.
