Results 1 to 29 of 29
Thread: ESC QUESTION, Hifei Swordfish PLUS 200 amp
    Aug 2012
    Wi
    175
    Default ESC QUESTION, Hifei Swordfish PLUS 200 amp
    Hi,
    someone got the listed ESC like me and can give me a detailed information?
    when i give full throttle, what color and how the esc flashs? mine blinks green every 0,5 seconds with full throttle, i think i read somewhere that it must be red and constant with full throttle, is that right?
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
    May 2008
    Oz
    2,981
    solid green
    turn the throttle adjust on transmitter to 120% and try again.
    some 2.4ghx Tx do not calibrate SF esc properly...
    DocW
    Aug 2012
    Wi
    175
    Quote Originally Posted by drwayne View Post
    solid green
    DocW
    i tryd, still flashing green every 0,5 seconds, set my spektrum to 125% throttle, tryd to calibrate the throttle endpoints new, esc new calibrated, still the same, hmmmm
    May 2008
    Oz
    2,981
    on spektrum, set throttle to 100%
    Calibrate esc again with this Tx setting.
    -- turn on Tx.
    -- hold throttle 100%
    -- turn on esc.
    -- "music" dling dling dling dling .. pause beep beep ..pause.. beep beep .. pause ... beep beep ...
    -- somewhere in middle of 2 beeps ( pause ) you release throttle back to zero
    now adjust Spektrum throttle to 125%
    try again.
    DocW
    Aug 2012
    Wi
    175
    -- turn on Tx.
    -- turn on esc.
    try again.
    DocW
    thats what i have done, hmmmmm
    maybe the esc dont get enough power? 37mm 2075kv dwind, twinsetup with 5s 80c 4000 mah
    Aug 2012
    Wi
    175
    latest firmware for ish 200+ amp i get from hifei.com via skype, before 3 days, so the firmware isnt the problem
    Aug 2012
    Wi
    175
    -- turn on Tx.
    -- turn on esc.
    try again.
    DocW
    got a vid for you, help me getting this stuff runnign corectly haha, i have no idea what to do. just uploading...
    Aug 2012
    Wi
    175
    so, here it is, on the first vid you can see i hold the throttle on the transmitter on 100%, connecting the esc with lipo, no 2 beeps with pauses between, hahaha, whats next?
    i tryd: spektrum 100% th settings, set esc with the first 4 beeps, not solid green with full throttle (as you can see), set throttle 125%, still not solid green, but a little bit more power.
    1. vid esc settings with weird sounds:
    2. Spektrum dx20 125% throttle:
    im getting frustrated
    Aug 2012
    Wi
    175
    and yes i set the esc´s first with 100% spektrum throttle settings and after setting them i change to 125%, i tried 125% first to and then tested, not working.
    lipos are fully charged for the tests.
    still same esc settings like lvs, startup, and the rest
    Aug 2012
    Wi
    175
    as you can see on the first vid the leds are only flashing with full throttle
    when setting up the esc´s i tried to realese the throttle after the first period of beeps and this funny sound, but when i do so it starts again, i tried to realese, press, realese, bla bla, when i realese it with the 5. beep, it starts 5x beep, funny sound, and again beeps till 10.
    May 2008
    Oz
    2,981
    in video #1
    you need to release throttle at 0.19 or 0.20 or 0.21 !
    there is one beep ... beep ... beep ... beep !
    not 2 .. have not heard this routine before, but means same.,
    W
    Aug 2012
    Wi
    175
    thats what i did, hmmmmm, any other ideas?
    Aug 2012
    Wi
    175
    i try today the traxxas transmiter when i get home, this poo must works -.-
    May 2008
    Oz
    2,981
    what usb setting for this esc ?
    Aug 2012
    Wi
    175
    lvc: 5cells (tryd already 2 cells lvc, maybe lvc was on, wasnt)
    Startup: standart (tryd soft and fast, fast startup is not good because he jumps from 20% throttle instantly to over 60% and he is screaming, dont want my boat try to fly)
    pwm rate: 8 khz (tryd 12 and 16)
    timing: auto
    Cutoff Voltage/Cell: 3.1
    Brake Types: no brakes
    Cutoff Type: Hard Cutoff
    Aug 2012
    Wi
    175
    i got a traxxas XO-1 and will take the receiver and transmitter to test it on the esc´s, there is definetly something wrong, 6 months im searching for a reason why this crap wont work, everythign done what is in my possibility, maybe tomorrow it works ;(
    Aug 2012
    Wi
    175
    with the last drve of my zonda i get only 34 km/h, lvc was off, 39mm props on 2075 lv dwind sss 37mm motors with 5s, thats really not ok ;(
    Aug 2012
    Wi
    175
    so, i tryd today 3 different transmitters, 1,5 hours working on this and i cant set the esc´s for 100% throttle, i tryd everything that is possible, still not solved, i writed a mail to hifei, lets see what they say to this.
    May 2008
    Oz
    2,981
    When you use USB it will show the throttle range setting. if this is more than 700us it is 100%....
    China has Chinese New Year holidays now.. every one is closed until maybe 20th !
    This is most strange
    1. does your Rx use power from esc ? I would try outside Rx battery ( use USB to turn of Rx power from esc )
    I hear the esc play tone for 4 cells in video #1
    You have set by USB to 4cell ?
    Set by USB the timing for medium.
    very unusual for 2x esc same fault..
    cheers
    W
    Aug 2012
    Wi
    175
    ah thats right, i will try to connect the esc´s with usb again
    Aug 2012
    Wi
    175
    Only 512 throttle range, what now?
    May 2008
    Oz
    2,981
    Quote Originally Posted by Mecka1990 View Post
    2am here.
    Let me sleep !
    Maybe I dream of answer haha
    Aug 2012
    Wi
    175
    HAHAHA, yesterday i writed and workd on the boat from 22 pm till 7 am, and yes i was here and writed everything good night, hahaha, i hope you find a answer :p
    Aug 2012
    Wi
    175
    drwayne, got a screenshot for you.
    you can show me yours? or someone others can show me that he really get 100% throttle?
    Aug 2012
    Wi
    175
    and this one is the second esc:
    whats now wrong? -.-
    Aug 2012
    Wi
    175
    i tryd now the traxxas TQI and the second both ESC got the same Parameters like before, nothing changed...
    May 2008
    Oz
    2,981
    here is SF200 on 4S.
    I think your problem is somehow Tx/Rx.
    Aug 2012
    Wi
    175
    what exactly you mean with Tx/Rx?
    Aug 2012
    Wi
    175
    SOLVED, i get it, finally, i needet to set my spektrum DX2.0 on 75% throttle, then i Setted up the Esc: 3 beeps when plugin in with holding Throttle Max forward, then comes 1 beep, pause, 2. beep, pause, 3. beep (release).
    after that, i give full throttle to record the data for the data logger, with about 20% throttle i change on the transmitter from 75% to 125%, and then i get the 100% throttle.
    oh man, that was a hard job, about 3 months working on this -.- (not all the time, every week 2-3 times)
    screen 1 = Esc on the Right side
    screen 2 = Esc on the left side
    how you can see the motors are working a little bit different, shoud i see that when driving in water?
