Results 1 to 7 of 7
Thread: T-180a placement
    949
    Default T-180a placement
    As the title says, where do most of you place the t-180a in the impulse?
    I have put it on the left or port side, but its a tight fit and hard to run the wires, so this time i'm thinking about putting up front infront of the batterys, i did cut some of the tray sides away to make clearence for the battery leads.
    testing will tell about cg and running profile but just like to know from those who run the 180 where they put it.
    949
    Any body?
    Apr 2011
    tx
    1,284
    I put a cf tray next to rail and mounted the 180 on it. I'll get you a pic.
    Apr 2011
    tx
    1,284
    Apr 2011
    tx
    1,284
    I epoxied the tray to the hull and the top of the rail. Works well.
    949
    Thanx for the pic, thats about how I have mine located but without the tray,I think I will come up with somthing like that.
    I could not help to notice that your cooling you motor first, most all cool theie esc first jmo, again thanks for the pic.
    Apr 2011
    tx
    1,284
    Yea I normally run it to the esc first but was short on tubing when I put it together. It runs so cool on 4s that I haven't worried about changing it.
    Thank for the heads up though.
