Page 1 of 2 12 LastLast
Results 1 to 30 of 46
Thread: HobbyWing Seaking 130A/180A High Voltage ???
    FR
    2,096
    Question HobbyWing Seaking 130A/180A High Voltage ???
    Hi,
    Do you know this ESC, is it a good value? Thanks
    Sep 2008
    1,494
    FR
    2,096
    What do you mean?
    Apr 2011
    5,666
    I would love to know too, it's been on my mind to ask. I just wish the "continuous amp" is rated higher, say 180A at the very least. I like Seaking 120a and 180a Low V ESC, for the price you can't beat them.
    I am putting back to service a PT 45 ( Neu 2215 1y) and was looking for a ESC that can handle 6s with ease, this was tempting ( price wise) but 130a is way too low, got instead a CC Hydra Ice 240 which can handle up to 8s.
    This is just my humble opinion, if I am off base, by all means correct me. Thanks.
    ...wish there is more review/discussion on this particular ESC.
    Jan 2008
    216
    I have had very good experience with the Seaking 130A HV . We ran them in our 1/8th scales at the FE nats. no problems . I have one in an Insane Gas mono with a NUE 2215 1.5 Y on 10 cells . Ive only raced it once , but test run it several times . Like the Sea king 180 A it needs to stay dry . Gary Rose ran one in his 43" DF Sniper , Big Leopard on 8 cells . It quit when it got wet , but worked again when it dried out.
    I run the Insane open with the ESC , RX , and Rudder servo in a radio box ala nitro and gas boats .
    Dick Roberts
    FR
    2,096
    Ok, for you this is a good ESC. I want to use them in a 50" mono twin setup with 2x10S, I' ve got Seaking 120A and 180A and I like them.
    This is for this 50'' deep vee Fountain P1 hull
    Apr 2011
    5,666
    Quote Originally Posted by Alfa Spirit View Post
    I understand, I was merely relaying my story in the hope that someone would give us some info that you were looking.
    @Flyguy55: thank you very much, you have given me just the info I wanted, next time I will consider that, I got the CC because it was a deal I can't refuse and I wanted one for a long time, now armed with your info I have more choices in the future.
    Sep 2010
    nj
    4,289
    My buddy tunnelvision is using a 130a hv in his MG on 6s and some other boats and loves them so far,
    Just need to water proof them like most esc.
    Jan 2008
    216
    I also hope Seaking builds a 180 or 200 plus . My hull is 43" long . It was as fast down the straights as the fastest gas monos . This was in Open Oval at a NAMBA Dist 19 race . I had to prop down to control heat .Ive had several other brands fail , including a CC 180 HV on 6S that ran fine in a Gas Jersey Skiff on a Seaking 180 LV .
    Jan 2013
    253
    What size bullet would u put on something like this or a 180 amp seaking? Paired with a tacon 4074 what size bullets would u recommend??
    Apr 2011
    5,666
    I use 5.5 mm, so far works great.
    Sep 2010
    nj
    4,289
    5.5 Are the standard for very good FE setups.
    ? ONLY IF THEY WORK
    FR
    2,096
    +1
    5,5mm everywhere: charger, batteries, esc, etc....
    Jan 2013
    253
    So u wouldn't recommend leaving 4 mm bullets even if they come with it?
    Sep 2010
    nj
    4,289
    No,
    Use 5.5MM on all Chargers,Cells, Esc's, Motor's, and they will stay happy,
    On mini boats you can run deans on the cells and 3.5MM on motor & esc.
    The 4MM have MORE resistance than 3.5MM and the 4MM are the worst plugs to use,
    In less you like this.
    ? ONLY IF THEY WORK
    Jan 2013
    253
    Alright I will go with 5.5 mm gold played connectors! But I wanna go 5.5 on everything but right now going with deans battery plugs is the easiest most versatile plug I can go with at the moment :/
    Sep 2010
    nj
    4,289
    So what boat is this for ?
    And what S cell and C rating are going to run ?
    And on what setup ?
    ? ONLY IF THEY WORK
    Jan 2013
    253
    Mystic I'm assuming by s cell this the correct answer, I am gonna run 2 2s 40c gens ace 5000 mah in series, Setup: tacon 4074 2150 kv, seaking 180 and at the moment an x645 but plan on getting an m445
    Sep 2010
    nj
    4,289
    On deans, That is not good.
    They will get hot and melt if you pull to many amp on them.
    The deans is the weakest link in the setup, They will only handle 50 amps.
    What is going on the esc to motor ?
    ? ONLY IF THEY WORK
    Jan 2013
    253
    5.5 mm bullets, what would u say about traxxas plugs? I might be able to pull of the bullet connector, the problem is that I don't have a sauder gun nor do I think I wanna get one at the moment
    Jan 2013
    253
    How do u set a series setup with bullets???
    6,453
    One thing you're gonna need in this hobby, is a soldering iron. They're cheap!
    Sep 2010
    nj
    4,289
    Also I like a mini torch to for 5.5 bullets and shrink wrap to.
    http://search.yahoo.com/r/_ylt=A0oG7...rch-42099.html
    ? ONLY IF THEY WORK
    Jan 2013
    253
    Ya I know there cheap it's just myself learning and my concern for safety! If I setup a series connection with bullets would I be able to shrink wrap the 2 wires together so I don't " loose the loose cable?
    Apr 2011
    5,666
    The two wires that come out of the battery need not be shrink wrapped together, you need them separated so you can connect them to the ESC as well. Alot depends on the location of the batt.packs and the ESC, but in general I haven't seen any batteries with bullet plugs having the wires bind together, unless that is not what you mean.
    The most important thing is you need to get protective caps for the bullet plugs, I make them myself out of shrink wraps but I believe Kintec sells them:http://kintecracing.com/Connectors___Adapters.html
    Sep 2010
    nj
    4,289
    Jan 2013
    253
    Ok and I've heard people say to solder one male and one female to the batteries???
    FR
    2,096
    The HobbyWing 130A/180A HV have an integrated anti spark, this ESC need only a cap bank, easy to build, 4 x 1000µF 63 Volts
    Apr 2011
    5,666
    Quote Originally Posted by Megabiker98 View Post
    Yes! I will post some pic. later.
    Jan 2013
    253
    Illtry to explain this as best as possible since my phone won't upload photos! But back to my series connector question, so when u solder something in series there are the 2 normal wires coming out of the esc each going to one plug, then there is a third stray wire connecting the two plugs, if I replace the plugs with bullets, what can I do to insure I don't lose the third "stray" wire?? Would I be able to shrink wrap it to the the other positive/negative wires? Or would that create problems??
